evo cam bearing 101
Old Mar 12, 2010 | 05:32 PM
  #31
Moog Player's Avatar
Moog Player
50,000 miles.
Old Mar 12, 2010 | 06:32 PM
  #32
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
This thread has been dead for 3 years...
Old Mar 12, 2010 | 07:08 PM
  #33
prodrag1320's Avatar
prodrag1320
if anyone has had this happen in any motor,to where it screwed up the bore the bearing presses into,XL to TC,we`ve repaired alot of them better than new,dont have to get new cases
Old Mar 22, 2010 | 04:25 PM
  #34
tenn.vol.'s Avatar
tenn.vol.
My bearing was just a tad worse that Moog Rider, out of an 97, FLHRI with
about 32K as I remember. Found during my annual oil change...Tenn.Vol.
Old Apr 5, 2010 | 02:49 PM
  #35
OnAnUltra's Avatar
OnAnUltra
Stage II
I'm guessing that the cam bearing is what exploded on mine this past Sat. 98 FLHRCI with 40K. I really didn't need this to happen, timing belt in my truck went Fri. night, now this.
Oh boy!
Old Apr 8, 2010 | 10:00 PM
  #36
Jahillsr's Avatar
Jahillsr
Bummer! Hope you're back on the road soon.
Oh boy!
Old Apr 26, 2010 | 09:11 PM
  #37
bstacey's Avatar
bstacey
mine too. pieces of bearing everywhere. pics in my profile of rebuild
Old Apr 27, 2010 | 08:09 AM
  #38
mayfly's Avatar
mayfly
Dam - that is quite the rebuild, did the bearing hose up the pistons and case or did you just strip it down that far to be sure ? what mods did you throw in during your rebuild ?
I am increasingly concerned that my 98 FLHRCI with 40K+ could be headed down this path.....
Old Apr 27, 2010 | 08:12 AM
  #39
mayfly's Avatar
mayfly
Oh boy!
onanultra - I am in Lewisberry near Ski Roundtop, LMK if you need a hand working on your RK, mine has the same mileage and may be a ticking time bomb as well, the hands on experience may help me in my undertaking of my own.
Old Apr 27, 2010 | 10:24 AM
  #40
bstacey's Avatar
bstacey
hi mayfly. yeah, we tore it right down to be sure. parts of the bearing were imbedded in the breather and scattered through the cam chest so was taking no chances. i'm stepping up to an ev27 cam and having the heads done. andrews lifters are also there and the new steel breather in place of the plastic one. from what i've heard the bad ana bearing started in the 1992 model and continued on for all the rest of the evolutions. the ana bearing has spacers between each roller which causes early failure while the torrington has a full roller system. i wish i'd caught mine sooner. you can go in through the nose cone for minimal teardown and use a bearing puller to get the old one out. this whole procedure is about 3- 5 hours and the bearing is about 8 bucks
