evo cam bearing 101
Old Jan 5, 2012 | 08:42 AM
  #51
stujoe's Avatar
stujoe
any one with a part numer its comming apart this weekend and would like to pick one up tommorow thanks sj
Old Jan 5, 2012 | 12:06 PM
  #52
Kushman's Avatar
Kushman
Originally Posted by pjb
you should have changed the cam, you would be happier if you did. I know how you feel, I left my 85 all stock/original until last year. My big reason to hold back was that the early evos had flat top pistons, with no valve notches. "Bolt in" cams won't work with them. I finally waited long enough that I could justify tearing into a perfectly good running engine (even though it was still running fine).
I did an EV27 cam, KB 9.5 pistons/rings, SE pushrods, harley B lifters, intake/exhaust valves and springs, and a S&S Super E.
Like you I had no real complaints before (except the original carb was kind of crappy), but I love it now.
I was thinking about switching over to a mid grade cam on my 85 but if I have to do all this I think I may wait untill I can justify it as well. After all if it aint broke dont fix it.
Old Jan 5, 2012 | 03:10 PM
  #53
Spanners39's Avatar
Spanners39
Go to your local dealer, they should have one in stock.
Old Jan 5, 2012 | 08:14 PM
  #54
stujoe's Avatar
stujoe
they gonna have the updated one or is it gonna be the same as the original?? i'll pull the cam and check the one that is in there and compare the two...think that i seen a pic of the old one and it has a cage in between the rollers right?? and the new one is all rollers??
Old Jan 5, 2012 | 10:04 PM
  #55
Spanners39's Avatar
Spanners39
You are correct. My dealer only ever stocks the torrington now but you may want to ask for the "Full complement bearing upgrade" and look in the box before paying for it.
Old Jan 5, 2012 | 10:37 PM
  #56
stujoe's Avatar
stujoe
dam lifters....trying to keep them up to get cam out...
Old Jan 6, 2012 | 02:09 AM
  #57
Spanners39's Avatar
Spanners39
Use a sheet of stiff but thin plastic in a horseshoe to hold them up....or just remove the lifter blocks and make life easier and quickerer......
Old Jan 6, 2012 | 05:42 AM
  #58
pjb's Avatar
pjb
I never have been able to figure out exactly when Harley went from the flat top pistons to pistons with valve notches, but I think it was sometime in 1985. I was never sure about mine, but when I took it apart they were flat top. No valve notches. A "bolt-in" cam would have clearance problems. I guess you could find out with a bore scope in the spark plug hole.
Old Jan 6, 2012 | 06:15 AM
  #59
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Your bike is an `89, it originally came with the Torrington B-138 cam Bearing, so you are ok there.
It would be a good idea to toss the lifters into the scrap bin and replace them while the cam chest is open.
Old Jan 6, 2012 | 07:33 PM
  #60
stujoe's Avatar
stujoe
cam brng looks ok...lifters look like they were replaced not long ago...few little marks in the cam but for the most part everything is ok.....the cam gear has andrews 1500 on the gear but on the cam lobe it has fx on one and 143 on the other....stuck my verniers on it...looks like its stock....hmmm any input would be great here...no marks or letters on the ends of the cam..?...i know the heads have been planed .060 and has a screaming eagle ig box on it..and m6 with cevlar clutch plates i think...the drive side looks good so im not going there..had the bore scope down mine but cant remember on the pistons...thanks for the help..
