Motorcycle lifts
Old May 15, 2011 | 08:22 AM
IDIDNTDOIT's Avatar
IDIDNTDOIT
I have the full table lift with foot pump from HF, throw the cheezy wheel chock away and mount the heavy duty one that "traps" the front wheel. I can pull up and have the front wheel snap in , get off and tie it down. I move the table around in the shop with the bike on it and have not felt afraid of it tipping. The drop out panel for rear wheel service is great!!!
Old May 15, 2011 | 09:25 AM
The Nuge's Avatar
The Nuge
every month Harbor freight has the coupons in easyridermag BUT every other month they have the table lift coupon for $289. amazing deal
Old May 16, 2011 | 07:08 AM
DMas's Avatar
DMas
I don't have room for a table lift so I got the Craftsman Yellow jack. works fine for what I need.
Old May 16, 2011 | 01:38 PM
Panthers65's Avatar
Panthers65
Had this problem when I first got the table lift. For about 2 weeks I'd drive the bike up on the lift and push it into the place where I normally stored the bike. Actually takes up less room side to side because the bike stands up straight and you can push it clear to the wall.
Old May 16, 2011 | 04:30 PM
k&j eglide's Avatar
k&j eglide
The cheap lift from Harbor Freight is the same as the cheap lift from Sears. Usually on sale for about $75. If you have money to burn, buy a $300 lift. I've taken rear wheels off (and on), left my Electraglide on the lift for the winter, used it as a dolly to move bikes around and never had any concerns or issues with stability, etc. The lift has a mechanical stop. Set that and even if the hydraulics leak your bike isn't going to end up in the floor. When I can afford an air powered lift I'm getting one, but only because I would like to work at a height better suited to my back.
Old May 17, 2011 | 04:25 PM
Beemervet's Avatar
Beemervet
I love my Handy, but..........
last I heard Handy was halting production and only filling orders placed before the shut-down.
Old May 19, 2011 | 10:07 AM
Idaho Scootertrash's Avatar
Idaho Scootertrash
Get a table lift. It is so much nicer when working on the bike. I picked mine up from an importer in Arlington, TX. It's a hydraulic foot pump type...if I had to do it over, I'd go pneumatic all the way. Usually I just push the bike up clamp it down. I did add some of that "don't slip in the shower" stuff for the ramp and the middle of the table...that and a 2x4 under the ramp's leading edge to mellow out the angle. I've had mine for 7 years and love it.
wizardfitznq
Apr 14, 2019 11:55 AM
Jwwhittle
Dec 4, 2017 08:04 PM
1HD1C
Aug 11, 2013 06:01 PM
Hawgnut
Jul 25, 2010 08:48 PM
the4thgearkid
May 9, 2009 08:27 PM
