meltage behind timer
Old May 15, 2011 | 12:54 PM
Cygnus x-1's Avatar
Cygnus x-1
Default meltage behind timer
I was taking the timer cover off to switch it with a new one and behind that there is a wired "sensor". No manual yet hasn't arrived. What is this, and what brand should I use to replace it with.
Old May 15, 2011 | 04:21 PM
97Ultra's Avatar
97Ultra
That would be the camshaft position sensor. The "meltage" is from the potting compund used in the sensors construction. This is a common problem.
Old May 15, 2011 | 04:37 PM
Spanners39's Avatar
Spanners39
They work even when they are melted and you would really only wanna use a H-D one to replace it.
Old May 15, 2011 | 07:28 PM
miacycles's Avatar
miacycles
Spanners speaks the truth, unless you want to change the ignition system to after market.
Old May 16, 2011 | 04:50 AM
Cygnus x-1's Avatar
Cygnus x-1
That's cool. Any advantage to upgrading ignition on stock motor?
Old May 16, 2011 | 06:34 AM
miacycles's Avatar
miacycles
Only if the stock curves,etc aren't the optimum set up for the engine. The real advantage is adjustability for future changes in the engine or if they keep making the fuel worse you will be able to adjust for it.
Old May 16, 2011 | 04:26 PM
Spanners39's Avatar
Spanners39
You can get the ones that have no module, its all in the cone, and they have dials to adjust stuff!!! Very good option if you plan on doing some tuning in the future.
bstein1994
Sep 26, 2024 08:43 PM
Shakee
Apr 22, 2020 10:50 PM
lillemann
EVO
33
Oct 17, 2018 05:36 PM
DocUSMC
Jun 11, 2012 11:37 AM
Brad223
Nov 22, 2010 07:54 PM
