Replacement cylinder with stock heads.
Old May 27, 2011 | 05:49 AM
Qonrad's Avatar
Qonrad
6th Gear
Default Replacement cylinder with stock heads.
I´m going to replace my 1997 EVO stock 80 cu cylinders and pistons.
Do I have to replace it with stock cylinders or could I go for some bigger cylinders without doing some work with the heads or crank...If so, how much could I raise the cylinder volume..?
Thanks.
Old May 27, 2011 | 06:02 AM
miacycles's Avatar
miacycles
For the most part, larger cylinders means you will have to split the cases and bore out the spigot holes to get any worthwhile gain in engine displacement. just bore out the stock cylinders enough to straighten out the bore. Then new pistons and rings. The old cylinders have been "heat cycled and will be more stable than new ones. Hope this helps.
Old May 28, 2011 | 03:39 AM
Spanners39's Avatar
Spanners39
Make sure whoever bores them knows what torque plates are and how to use them.
Old May 30, 2011 | 02:19 AM
Qonrad's Avatar
Qonrad
6th Gear
Thanks for usefull replies.
I se the point using the old cylinders and bore them.
But here in Norway it would be more expensive to bore, than order a new stock cylinders & piston kit incl. all the engine gaskets from the US.
I also se the issues about the old cylinders is "settled"... but do you guys mean there is a risk to put new cylinders on, and are we talking lekkage and other troubles..?
Old May 30, 2011 | 06:12 AM
miacycles's Avatar
miacycles
Sometimes new cylinders will take a set after being heat cycled a few times and be slightly out of round. This is not a big deal on an average street bike, however if you are looking for the best bang for your buck then the re-bore is the way to go.
Old May 31, 2011 | 04:41 AM
grbrown's Avatar
grbrown
Red face
Hi from the UK. There is substantial support for Harleys available in Europe, so I am intrigued by your comment about it costing more to buy new pistons and rebore your current cylinders. That goes against my experience over many years! A pair of pistons is cheaper than a set of pistons and cylinders! I have imported Harley parts to the UK for many years and shipping costs from the USA are extremely expensive, expecially for heavy things, plus you will probably pay import duties and taxes to the Norwegian taxman. Have you taken those into account?
I suggest you look further afield, such as Zodiac (in Holland). They have at least a dozen agents in Norway and import many well known brands from the USA. I am sure at least one of them can rebore your cylinders, even if you have to send them through the post!
To increase the engine size of an Evo is expensive compared with a twincam. Increasing cylinder diameter requires machining the crankcases, as John has already stated. An alternative (which I have done) is to stroke to 89ci, but that also requires dismantling the engine. You can improve performance of a stock size evo significantly by careful tuning, matching cams, compression ratio and head work. I am sure at least one of those Zodiac dealers can help you!
Old May 31, 2011 | 06:36 AM
Qonrad's Avatar
Qonrad
6th Gear
Thanks for following up.
I really don´t need more power, I have andrews 27 cam and screaming eagle ignition. But the idea came up if I could choose a number bigger cylinder & pistons since I have to go all the way down to the block.
The reason is that it´s has slightly started to burn oil.
I went to the local dealer to get a opinion. They concluded that is either the valve seals, guides or rings. If they should take the job and maybe rebore, it would cost about USD 3000-3700,-
So I decided it would be a nice winterjob. Since I would do this properly I thought it was a good idea to replace both cylinders and pistons since I find a cylinder & pistons kit all the gaskets to the price of USD 1055,- incl. Norwegian taxes and shipping.
In Norway labour cost approx. USD 200,- per hour + the material.
But in the end I have been convinced by you guys that the safest thing to do is rebore my old cylinders with fresh pistons.
Old May 31, 2011 | 07:07 AM
grbrown's Avatar
grbrown
Thumbs up
Ouch. With labour costs that high it is certainly worth doing as much as you can yourself! Best of luck and let us know how things work out.
Old May 31, 2011 | 05:25 PM
miacycles's Avatar
miacycles
$200 per hour??? Can I get a work visa???? What is the cost of living in Norway???? I am going to print this out and when my customers complain about $50 per hour, I will show it to them.
Old Jun 1, 2011 | 03:29 AM
grbrown's Avatar
grbrown
Exclamation
I have never been to Norway John, but my brother has. It is very expensive! Don't even think of having a beer....
