Clutch Adjusting Problem
Old Jun 8, 2011 | 05:19 PM
  #41
Bama91's Avatar
Bama91
It had the piece to hook the cable to the ramp hook. I am putting it together now.
Old Jun 8, 2011 | 05:47 PM
  #42
Dr.Hess's Avatar
Dr.Hess
Was this a separate piece that attached to the ramp with bolts? Look at a factory drawing of that side and make sure you don't have an extra piece in there. I don't like those easy clutch things.
Old Jun 8, 2011 | 06:05 PM
  #43
Bama91's Avatar
Bama91
No it didn't bolt in. It hooked on the cable end and then had to turn it certain way to put it in the hook.
Old Jun 8, 2011 | 06:28 PM
  #44
95yj's Avatar
95yj
That's the stock ramp and coupling.
Old Jun 8, 2011 | 09:52 PM
  #45
Dr.Hess's Avatar
Dr.Hess
That's good. The problem I have with the "easy" adapters is that it becomes easier because you get more leverage. However, you still have the same amount of lever travel, and there is no free lunch, so the same amount of lever travel now moves the clutch less distance. There isn't exactly a surplus of distance there to start with. I had a shop put an "easy" kit on Dr.Linda's Sportster, and I think it wiped out the new clutch. I took that thing off and she's back to building up that left forearm muscle set.
Old Jun 8, 2011 | 11:19 PM
  #46
95yj's Avatar
95yj
http://www.amazon.com/Hand-Grip-Stre.../dp/B003UJFN96
douglase3
Apr 17, 2023 06:01 AM
Pimonberg
Mar 11, 2021 09:34 PM
griffsyj
Nov 29, 2012 09:06 PM
mrbassman
Jun 6, 2011 03:22 PM
TRacer
May 24, 2011 11:50 AM
