Baker 6OD Installation
Old Jun 1, 2011 | 09:43 PM
1997bagger's Avatar
1997bagger
Default Baker 6OD Installation
Came across a good deal on a Baker 6 speed gear set and will be sliding it in shortly, had an output shaft inner seal leaking and now was the time. Transmisssion case is bare and make a note if you want to attempt this yourself, buy the main bearing remover tool and a big pair of snap ring pliers you will appreciate it! If you read special tools are not needed for disassembly, throw the bull$hit card.
Pics of assembly will follow in this installation process
Old Jun 2, 2011 | 01:26 AM
Holster Maker's Avatar
Holster Maker
Fantastic...keep us posted. I know you mentioned it before when I was thinking of it. I'm still very interested in the 6 spd.
Man this is exciting, can't wait for your first road trip report.
good luck.
Old Jun 2, 2011 | 06:47 AM
miacycles's Avatar
miacycles
If the tranny is a close ratio you may want to consider putting a one tooth smaller pulley on the tranny. We do this on most of the heavier bikes that we install OD six speeds in, especially if you ride two-up. his will give you a little more launch and have very little effect on the top end. Hope this helps.
Old Jun 2, 2011 | 07:58 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Make a bearing press, easy to do. Only had to buy threaded stock from home depot as I already have the steel. Drilled 2 holes and used a sheer to make a "round" shape to fit. I am sure it only cost less than $2.00.
Old Jun 2, 2011 | 01:51 PM
Brettfullthrottle's Avatar
Brettfullthrottle
Thanks for the post! I have been thinking of a six speed myself and am curious as to the work that needs to be performed! keepus posted!
Old Jun 2, 2011 | 09:13 PM
1997bagger's Avatar
1997bagger
Mia, have taken everything into consideration, big bike, 6'3" donut eating rider and ride some 2 up. Baker is a 3.24 first gear, already have 30 tooth and primary is the 3.37 so I am low with the 6th to motor down the road and still in the power range.
Easy to put the main bearing back together but removing it is a task, I made a tool to remove it but cost me 4 hours of time and a struggle, the correct tool would take less than 10 minutes. I had access to the correct tool but was currently broke and didn't know when the new parts would arrive.
Old Jun 4, 2011 | 07:32 PM
chop66's Avatar
chop66
When it gets time i wanna put a six speed OD gearset in my bike but it seems baker does not make one for my application, all I have found is the revtech 6spd OD. cant wait to hear your ride report. Thanks.
Old Jun 12, 2011 | 08:44 PM
1997bagger's Avatar
1997bagger
Started the picture process, this case didn't need any clearancing per Baker guidelines in the instructions. Waiting for a countershaft bearing to continue. Baker is on the right with the Redline Shockproof clinging to it.
Old Jun 12, 2011 | 11:45 PM
Spanners39's Avatar
Spanners39
Amazing how they squeeze all those gears in there....looks like a fairly straight forward install....
Old Jun 16, 2011 | 04:59 PM
gump305's Avatar
gump305
Can you give any updates to how it going so far?
