never thought changing jets help that much
Old Jun 13, 2011 | 08:19 AM
bubba4u's Avatar
bubba4u
i took a 160 mile ride on it just to check milage, i'm getting around 42MPG at regular riding and way more pull and accel. at WOT than i did with the 72 main
Old Jun 14, 2011 | 09:30 PM
dstiger's Avatar
dstiger
Originally Posted by 95yj
You know your main jet is hardly ever used. Just at 3/4 to full throttle. The rest of the time you're running off your slot jet or your idle mixture or both.
The easiest way to get close on your main jet is to get out in some open space with a warmed up bike. Get into 3rd or 4th or 5th and get running at full throttle. Back the throttle off quickly to 3/4 and see what the bike does. If it actually picks up some speed, your main is too big. If it stumbles, it's too small. If it keeps running good but just slows down a bit, then you're within a number or two of the correct jet.
But you can't really do anything until you get your idle mixture perfect and get really close on the pilot jet.
I second that!
gregjo1948
Aug 19, 2015 07:22 AM
DannyNCCmcr
Carburetor Related
Aug 27, 2014 07:26 PM
som69
EVO
May 30, 2013 07:47 AM
all-one
Shovelhead
24
May 4, 2010 10:05 PM
NakedSnowman
Exhaust System Topics
Mar 1, 2008 05:03 PM
