What does a loose primary chain sound like?
Old Jun 15, 2011 | 07:18 AM
JohnnyC's Avatar
JohnnyC
Default What does a loose primary chain sound like?
Having some noise issues in my primary. Seems to follow transmission activity.
So what does a loose primary chain sound like?
Old Jun 15, 2011 | 08:01 AM
1998fxd's Avatar
1998fxd
pull your inspection plate and youll be able to feel your chain. i think you should have no more than 5/8 of play in the chain. i woud think a loose chain would be more of a slapping sound as it would.be rubbing on your primary case
Old Jun 15, 2011 | 08:18 AM
carlgrover's Avatar
carlgrover
I think the play is 5/8" to 7/8" at the tightest point on the chain.
Old Jun 15, 2011 | 09:16 AM
Charlie Bone's Avatar
Charlie Bone
A REALLY loose chain will knock inside the primary. Mine did it only when cold and went away after it warmed up.
Old Jun 15, 2011 | 11:19 AM
NutterFLH's Avatar
NutterFLH
Loose chain would make noise at idle or at some rvs without load, neutral gear that is.
Slapping chain makes noise something like this at idle: "clik,clik.....clik,clik,clik....clik...clik,click ,click....."
Old Jun 15, 2011 | 12:27 PM
JohnnyC's Avatar
JohnnyC
Thanks for the responses.
I've done a lot of reading today and think it's the clutch hub bearing. Now I need to tear into it and see.
Old Jun 15, 2011 | 03:16 PM
Jim Kraft's Avatar
Jim Kraft
The only time the clutch hub brg. will be noisy, is when you have the clutch pulled in. My son just had to replace his.
Old Jun 15, 2011 | 04:38 PM
JohnnyC's Avatar
JohnnyC
Originally Posted by Jim Kraft
The only time the clutch hub bearing will be noisy, is when you have the clutch pulled in. My son just had to replace his.
Thanks for that info.
I had a moment to go out to the garage and check what I could hear while sitting in the drive, I had been going down the road all the other times.
Clutch lever engaged / Clutch released: a clattering, churning noise begins and a slight "out of balnce" feel in the bike, along with a scrapping / grating sound.
Clutch lever released / Clutch engaged: slightly noisy, noise stops when putting transmission in gear.
The scrapping sounds to me like the primary chain is dragging and contacting the case.
The wobbly, or out of balance feel makes me think a bad clutch hub bearing / loose compensator that would allow them to shift and wobble when disengaged and in neutral.
The scrapping grating sounds are probably the primary chain as it loosens and scrapes along the case from the wobbling hub / compensator.
It's odd how when under load accelerating the chain slack noises seem to go away, and when coasting in gear it's noisy.
Can't wait to open it up. Have to fit it into my schedule.
Old Jan 14, 2020 | 12:27 AM
SJT's Avatar
SJT
i hate searching a problem and the conclusion is omitted.. I have no shame in reviving this old thread.. what was it Johnny c
kbatrph
EVO
Jun 4, 2018 10:56 AM
extremeshot
Apr 28, 2016 01:27 PM
faber
Mar 7, 2010 01:13 AM
njesus
May 14, 2008 01:30 PM
vernfindley
Oct 18, 2007 06:54 PM
