Leaking Cam Seal
Old Jun 17, 2011 | 10:37 PM
2006FLST's Avatar
2006FLST
Default Leaking Cam Seal
Okay I put a new cam in and now weeks later I see that my camshaft seal is leaking up behind my pickup for the ignition. My question is how hard are these to press out of the cam cover itself? And should I go ahead and replace the cam bushing?
Old Jun 18, 2011 | 07:03 AM
miacycles's Avatar
miacycles
The easiest way is to remove the nosecone and tap the seal out from behind. That being said if you carefully take two small screws and screw them carefully into the metal part of the seal. The slowly work from side to side you can work the seal out. Then all you need is a piece of tubing to tap the new seal in, be sure to put some grease on the rubber part of the seal before you put it back in.
The bushing should be good if it didn't leak before the cam change. Hope this helps.
Old Jun 18, 2011 | 12:35 PM
NutterFLH's Avatar
NutterFLH
New cam needs a new seal. Even if You would not change the cam it might leak once the cover was off the engine.
Seals and o-rings should be replaced every time You take some parts off the engine. No matter if the seal is good, just replace it. Important rule while working on bikes.
Old Jun 18, 2011 | 04:46 PM
Spanners39's Avatar
Spanners39
Check the bushing before removing the nose cone by gently putting pressure on the ign rotor.....I had a Sporty that had 50 thou play there once......needed a bush ;-)
Old Jun 18, 2011 | 10:46 PM
2006FLST's Avatar
2006FLST
Replaced it today. Drove for about 20 miles and no leaking. Thanks guys.
jimmyjennings60@gmail.com
Shovelhead
Jun 27, 2019 07:49 AM
Doug S
EVO
14
Dec 23, 2018 12:05 PM
Rt13MFer
EVO
Dec 21, 2017 01:46 PM
redrott
EVO
Jul 11, 2010 08:44 AM
LeadDoggy
EVO
18
Aug 10, 2007 01:08 PM
