oil pump install
Old Nov 3, 2006 | 12:35 PM
cane22's Avatar
cane22
Stage III
Default oil pump install
hey to all,im getting ready to install a s&s hvhp oil pump and the motor is in the bike so i will be using the excisting drive shaft does anyone have any tips on what i should expect...thanks
Old Nov 4, 2006 | 09:37 AM
RudeDog's Avatar
RudeDog
Default RE: oil pump install
The snap ring at the end of the oil pump shaft on the gear case side is a pain in the a$$. Other than that it is a fairly simple operation.
When you go to tighten the bolts make sure you use an inch pound torque wrench because if you snap a bolt or strip a thread you'll have to pull the motor to fix the problem.
imboden
Shovelhead
Oct 7, 2013 05:04 PM
speakerfritz
Apr 19, 2012 07:35 PM
jurgie
Mar 25, 2011 07:50 AM
05ROADGLIDE
Feb 21, 2011 06:38 PM
cane22
Exhaust System Topics
Nov 3, 2006 12:57 PM
