Total Oil Change
Old Nov 8, 2006 | 08:10 AM
nobody's Avatar
nobody
Default RE: Total Oil Change
ORIGINAL: Hackd
I checked out the Rogue Chopper site. Their product seems to be a decent idea if you want to purge your system of old oil. If I was gonna do that, I'd probably run a few quarts of the new oil through the setup, re-drain the oil pan/bag. Then fill anew before installing the filter. Remember, on the EVO oiling system, the last stop before the tank/pan is the filter.
If you use the scavenger, then you dont need to run extra oil through the system,just drain,then refill,remove oil filter then fit scavenger and start engine,watch dirty oil come out of tube ,when clean oil starts coming out,switch off engine,remove scavenger ,fit oil filter,top up oil level and done,with nice clean oil.Did mine tonight as a matter of fact,and worked nicely,without any mess,which is what I like.
[IMG]local://upfiles/7663/5D72484E5F2549B6A17039F44DEE79E3.jpg[/IMG]
Old Nov 8, 2006 | 08:26 AM
RudeDog's Avatar
RudeDog
I would support doing what John suggests. Once a year getting out the 24 oz. out for a better winter storage prepared engine.
From what I am reading it looks as if it's not that difficult.
Old Aug 5, 2008 | 01:58 AM
OzStyle's Avatar
OzStyle
Stage II
ORIGINAL: Hackd
&nbsp\\;
Sorry to dig this thread up from the depths, but ive just bought my first Harley and am trying to learn a bit.
&nbsp\\;
Based on&nbsp\\;Hackd saying the filter is the last stop for the oil, is there any benefit to removing the oil return line at the tank, other than being able to pump out the oil in the return line?
&nbsp\\;
Basically im trying to say if i run the bike without the filter until fresh oil comes out, then put a new filter on, should i&nbsp\\;have any worries, and does that keep oil pressure within the engine???
&nbsp\\;
&nbsp\\;
Im still after the gear oil capacity for a 95 Heritage Softail too if anyone happens to be able to help me out.
&nbsp\\;
Cheers.
clackavosticus
Mar 23, 2017 05:11 PM
joe10softail
Mar 26, 2016 07:50 PM
Knights2TheEnd
Sep 14, 2012 08:30 PM
TUCCI
Oil Archive (no new posts)
Dec 22, 2011 08:14 PM
ajonojono
Aug 19, 2008 09:01 PM
