slow jet good main ?
Old Jul 11, 2011 | 08:58 PM
miacycles's Avatar
miacycles
We use the sporty needle unmodified slide and stock springs with stock pilot and main. Turn the idle mixture screw out two turns to start, then re-adjust after the engine is warm.
2500 RPM's is where the carb transitions so the sporty needle should take care of that. Shimming the needle up does not do the same thing and we find it does not make the mixture as good as the sporty needle. The above will give you dyno readings within a few horsepower or so of some of the best dyno tunes we've seen for a lot less money. Hope this helps.
massparanoia
Oct 26, 2015 08:43 AM
Bill C
Carburetor Related
May 31, 2011 10:09 PM
jm04
Jul 21, 2010 03:13 PM
Ruylemaker
Aug 6, 2007 07:55 PM
Johneb48
Exhaust System Topics
Oct 23, 2005 03:03 PM
