Which Wider Wheel?
I haven't started this yet and it may be a while before I prove if it will work or not. I will report on progress as I go along!
This Deuce wheel had better darned well fit when it has a tyre on it. I have had problems I didnt anticipate, but that is what a dry fit is for. Ive had a lot of those this weekend, just working with the bare wheel!
At 4.5 this rim is much wider than our stock 3 rim and when installed it overhangs the rear calliper a lot more, which steals all the wriggle room for getting the wheel in and out. Once in place it is fine, but getting it there has involved a lot of effort, finding a workable installation process.
Having tried in vain I found that the wheel wouldnt just pop in, nice and easy like, as the calliper hits the inside of the rim, preventing the rotor from engaging the pads. So I tried various ways of getting it into the bike, including removing the inner brake pad, then slackening all the rotor screws, but eventually removed the pulley and rotor, before I finally got the wheel where it belongs.
I have at least proved that once in place, with all the spacers etc, everything seems to line up right. I say that as the bearings are ž ID and my current setup is 1, so I cant install the axle yet, but a piece of engineering grade garden bamboo served almost as well, as you can see! It proves that the geometry of the hub is the same as other stock sealed-bearing rear wheels and they should all work together fine.
This was the first time I have removed my rear wheel, since installing a later swingarm and 1 axle set-up. The axle nut is 35mm AF and after a season in place required an extender bar just to slacken it. I am fast coming to realise that roadside rear wheel removal has become a thing of the past! So fiddling around to get my Deuce wheel in and out has become less of a problem. If I can do it behind a closed door at home that will have to do!
Next step is to get a tyre fitted and following that a 1 bearing set, so I can see what other challenges lie in wait. I suspect that with a tyre fitted it will be fun squeezing the wheel into place. My chosen tyre is a 160/70VR17 Avon 'Storm 2 Ultra', with a load rating of 79 or 963 pounds, which is largely what this is all about. The step after that will be checking fender clearance! Fingers crossed ..
I was going to paint this wheel black, to match the front, but I dont think I will bother now paint wont survive the bruising of getting the wheel in and out!
Dunlop D401 130/90 MT compared with Avon Storm 2 Ultra 160/70. Just the small matter of squeezing it into the bike........
Fitted width measures 167mm, which is just one mm wider than the brochure.
Next para added later:
And here is the evidence. I have commented before on HDF that when fitting oversize tyres, this is how to check if there is clearance between tyre and belt. Photo shows looking down the pulley side of the tyre, with top and bottom edges of the tyre in line with each other. As you can see, the only visible part of the pulley is the inside flange. The thickness of that is the clearance I will have, when everything is tightened up and in place! No need to bother with wheel alignment, just set the clearance, where tyre and belt come closest, to that dimension. Simples!
Next para added even later:
I could slip in a thin spacer behind the pulley, to marginally improve clearance, but will size that up when I get my 1" bearings installed and can fit the wheel for real. One step at a time!
Fender next. Well that can best be described as a running fit with my original fender! I think the tyre sidewalls would need to be lubricated, so it could move up and down inside. Fender is exactly as wide as the tyre! Fortunately I have a later wider one to hand. At least the wheel fits in place in the bike, although with both pulley and rotor removed.
With the suspension on full extension, bike in the air, the tyre doesn't seem too close to anything, but what I will do next (I have removed the shocks) is to jack the wheel up to simulate full compression of the shocks, to see how things look then. I do wish this fender was a bit wider.....
I have a pretty large selection of discarded nuts and bolts, but can't find just the right ones to finally fasten the new rear fender in place, so I have another wait for parts. What a great thing is the internet and small specialist businesses!
As with my wide belt and 140/90 tyre of a few years ago I have a snug 3/16" clearance between my tyre and current narrow belt. I'm happy with that and will trim the belt guard to suit, when I am closer to being road ready.
