runability help
Old Aug 1, 2011 | 03:39 PM
Spanners39's Avatar
Spanners39
Originally Posted by Stiggy
To say you're over carbed is an under-statement. Someone might trade you for an E on EBAY perhaps.
And I was never a big fan of the ignition systems on the 90's Harleys either. My favorite was the mechanical ( advance weights) Dyna S Dual Fire Ignition with a good 5 ohm coil.
Very dependable and not expensive.
Trouble is, nobody makes an advance unit that isn't a mini-grenade anymore.....I have a collection of exploded advance units in my workshop...solid state does it for me these days :-)
Old Aug 7, 2011 | 12:25 AM
akmorris81's Avatar
akmorris81
well just to update everyone on whats going on....i couldn't find anyone to help out or trade carbs, so i finally got enough cash together and ordered the S&S Super E kit for my bike should be here in a couple days, as soon as i get it i will slap it on and give another update. And on that note if anyone needs a Super G kit i can make you a hell of a deal
Old Aug 7, 2011 | 01:17 AM
KingPinVinny's Avatar
KingPinVinny
Id buy if from u just to throw it away
Old Aug 9, 2011 | 08:20 PM
Glider rider's Avatar
Glider rider
If you still have the rubber intake spray it with starting fluid at idle. If the idle jumps you have a leak. I replaced mine with a solid intake.
Old Aug 10, 2011 | 12:44 AM
akmorris81's Avatar
akmorris81
no rubber intake, i'm still waiting for my carb to show up...supposed to be here today, looks like tomorrow...i'll keep ya posted
Old Aug 14, 2011 | 03:06 PM
akmorris81's Avatar
akmorris81
Well i put the super e on and adjusted it, runs great accelerates good, with no load on it. Going down highway when i get about 75 mph it doesn't matter if i roll throttle or snap it feels like bike cuts down to 1 cyl any suggestion?
Old Aug 14, 2011 | 05:33 PM
Spanners39's Avatar
Spanners39
Stuffed coil, dead plug or maybe the accelerator pump is adjusted wrong?
Old Aug 14, 2011 | 05:41 PM
akmorris81's Avatar
akmorris81
Gots new plugs, I'm almost positive accel pump adjusted good. The could both primary and secondary are within resistance specs. Could my main jet be to large?
Old Aug 14, 2011 | 05:57 PM
miacycles's Avatar
miacycles
Check your plug wires, both battery terminals, and the grounds
Old Aug 16, 2011 | 12:16 AM
akmorris81's Avatar
akmorris81
Thanks for all the help, i ended up putting a spare ignition could i got from my buddy and it cleared up. Bike is running ***** out
