lower fairings
Old Aug 30, 2011 | 01:58 PM
D1gger's Avatar
D1gger
So either I pass on these and try to find lowers from a Tour/Road glide, pre-'10, or I change all three fairing mounts to raise up the fairing 1/4" and it might still not be enough to clear the lowers? Is that about right?
I am interested in the snap-on leather cover lowers, I haven't seen these except for specific aftermarket crash bars. Do they make them for stock crash bars? Where can I find them?
Old Aug 30, 2011 | 11:12 PM
Ultra89Rider's Avatar
Ultra89Rider
Current part from the 2012 Harley Accessory Catalog.
Protective Soft Lowers
Constructed of reinforced vinyl with polyester backing and black snaps. Install on engine guard for protection against the elements. Easy installation and removal. Should not be used when air temperature is above 50 degrees Fahrenheit.
58502-80C
Fits '80-later Touring and Trike models equipped with engine guards. Does not fit with Mustache Engine Guards.
MSRP $49.95
Link to the PDF Instructions
Old Aug 31, 2011 | 06:16 PM
notlost_nc's Avatar
notlost_nc
The Tour glide and Road glide are two seperate fairings. My Tour glide fairing is one piece, the newer road glide fairings have an inner & outer fairing. Have a good look before you drop money on new parts.
Old Sep 1, 2011 | 11:49 PM
D1gger's Avatar
D1gger
58502-80C
MSRP $49.95
I asked about these at the dealership today when I was in there picking up some parts and he brought out what looked like padded cordura nylon things that slipped over the crash bars and fastened to the down tube of the frame with 2 nylon straps with quick-connect buckles. These were priced $58 and the description was the same as above. I noticed a couple problems with the different style ones he showed me though, there were no cut outs for my highway pegs and also no provision for my fairing/turn signal mounts. They would have needed modified to even come close to fitting my Tour Glide. I like the idea of the soft lowers though and the PDF instructions you linked to show a different style that would fit my bike without mods. Are the vinyl ones with snaps still available or were they replaced by the padded cordura nylon ones with plastic buckles?
Old Sep 2, 2011 | 01:13 AM
Ultra89Rider
I would check with a different dealer. It sounds like the one you checked is trying to put something over that is not the part from Harley listed in the Catalog. I have seen them. It is listed just as listed.
ggf
May 19, 2012 05:34 PM
GEsails
Dec 12, 2010 12:27 PM
JSwan
Feb 3, 2009 06:53 AM
harleyhoots
Dec 19, 2008 09:21 PM
gilbos440rt
May 31, 2006 07:04 PM
