1990 trans problem
Old Sep 18, 2011 | 10:26 AM
pd76's Avatar
pd76
Default 1990 trans problem
i was cruising about 35 mph and tried to go to 3rd. gear and found that it would not go into 3-5th. gears, thought i stripped the shifter but had not, took shifter loose and attempted to move shift arm to 3rd - 5th. but it is al the way back and still only goes into 2nd. can i fix this . the tranny is not making any noise runs good in 1st. and 2nd. Help HD brothers 1990 electra glide classic
Old Sep 18, 2011 | 12:48 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Disconnect the shift linkage rod where it connects to the transmission shift lever, and make sure the shift lever at the transmission has not slipped on the shifter shaft, and that it is tight to the shaft.
How far back is the shift lever going? If it contacts the primary case, it has slipped on the shaft.
Old Sep 18, 2011 | 01:33 PM
pd76's Avatar
pd76
it doe's go back about to yhat position but the screw that tightens it to the shaft seems tight
Old Sep 18, 2011 | 01:45 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Try to wobble the lever on the shaft, you may find that it is loose, a very common occurrence.
Old Sep 18, 2011 | 01:58 PM
pd76's Avatar
pd76
ok will try that
cwsharp
Aug 22, 2022 11:54 PM
Fureek
11
May 16, 2019 12:45 AM
JfrenchFLHX09
Oct 17, 2015 07:59 PM
Next In Line
Apr 7, 2015 04:51 PM
Hoblick
Aug 29, 2011 09:32 AM
