Just wondering if I will need to remove the gas tank to be able to put in new spark plug wires???? I realize there is a couple of clips for the wires under the tank and I'm hoping to be able to push them in with a screwdriver without having to remove the tank. Any input or advice would be appreciated. Thanks in advance!
I am not for sure about the carburetor models.....
But for the EFI models....it is pain to replace the wires without removing the tank. I replaced mine without removing the tank....and it sucked. The hardest part was to fully seat the wire to the coil. It would probably been easier and maybe quicker if I just removed the tank.
Too bad they weren't designed like the Dyna or FXR's.......5 minutes tops to replace wires.
Thanks EVO rider. Unfortunately I think the tanks is gonna have to come off. I hear you with the older models being so much easier to install. I have a 87 Sporty as well and it took me all of 5 mins to install plug wires.
Johhnny, Gump all good advice. I'm definitely going to change petcock screen and blow out gas lines and flush out tank. I live in Toronto Canada so my riding days are coming to an end so I have time to do what you all have advised. Cheers and thanks!!
