rejet needed?
Old Dec 11, 2011 | 04:48 PM
dc1450's Avatar
dc1450
Originally Posted by Spanners39
Have to disagree on this point...before I added an EV27 I went from a 165 to a 185 just to keep up with the K&N filter. I used to run a bike shop and we always sold jets with a K&N filter....we even had a calculator to work out the correct jet sizes....you can hole a piston on a Harley with the wrong jets.
One point though...in the USA you have way different gas so we tend to jet bigger in NZ...a 50 slow and a 200 main is not uncommon....
You are correct about a lean condition holing a piston but, there has to be some difference with your gas down under. I have run this combo on quite a few Evos and never had a lean condition........in the USA. The Yost tube supposedly atomizes the fuel better. It also comes with a drill to open up the hole in the slide so it opens quicker. It has a needle that matches the emulsion tube, this also works to richen the mixture sooner in the throttle throw. The only time the main jet size is a factor for a lean condition is at WOT which happens how often on the street?
Maybe, if I was actually racing on a track, I may need a slightly larger main jet, but on the street, the stock jet is fine.
D-rob92
Jun 14, 2013 08:38 AM
Little88jr@yahoo.com
Carburetor Related
Jun 20, 2011 02:31 AM
MechsHands
Mar 26, 2010 08:36 AM
tnhd06
May 15, 2008 09:09 AM
Lord Tarl
Jun 1, 2007 10:00 AM
