Best Battery Cables
Old Jan 3, 2012 | 07:04 AM
Dr.Hess's Avatar
Dr.Hess
Gold is used in electrical connections because it does not oxidize. When you watch those diving treasure hunting shows, not that everything is junk on the bottom of the ocean after a short time, but gold still looks like the day it hit the bottom after 500 years of salt water.
Old Jan 3, 2012 | 08:05 PM
tjones's Avatar
tjones
I was always told that electricity flows on the outside of the wire, the more strands the more surface area for the electricity to flow.
Old Jan 3, 2012 | 09:32 PM
topfuel7's Avatar
topfuel7
The 4 gauge stinger high voltage stereo wire works very good. You can buy the 4 gauge lugs at auto parts stores with the correct hole for the battery end and the correct hole for the starter end also. I use Accel spiral core wires on my cars. Those plug wire kits come with a two piece crimping tool that works perfect for crimping the 4 gauge lugs onto the wire.
Old Jan 4, 2012 | 04:17 AM
grbrown's Avatar
grbrown
Wink
I don't think electricity is bothered how or where it flows. Only takes a mains shock to demonstrate that! Lightning doesn't even bother with wire and that is shifting serious energy.....
Old Jan 4, 2012 | 08:12 AM
topfuel7's Avatar
topfuel7
Thats what they say. Think of it like this. Each strand becomes a reversed water hose with the water traveling on the outside of the hose. The more water hoses there are the more electricity can flow freely.
Old Jan 4, 2012 | 08:19 AM
Dr.Hess's Avatar
Dr.Hess
I think the whole "outside of the wire" thing is an interesting theory, but besides some rare cases of high power RF, I don't think it works that way and after 35+ years in electronics, I'm gonna say "show me the study." I think that at this point, it is what I call "net wisdom," that is, someone read it on teh intr4w3bz, y0, and posted it somewhere else. Especially at DC (where our starters work), the bigger the total copper cross section, the less resistance, regardless of whether it is one solid wire or 1000 strands.
Old Jan 4, 2012 | 08:54 AM
rivercityslim's Avatar
rivercityslim
That's all well and good, but the bottom line is that when replacing battery or replacing/rebuilding starter, it only makes sense to replace the old cables, especially given the relatively small investment required. As Miacycles said, any of the name brand aftermarket soft flexible ones with lots of strands will be an improvement over your old ones. I chose the Spyke Superflex cables (less than $50 for the 'kit'), but there are others that are probably just as good and around the same price.
Old Jan 4, 2012 | 10:38 AM
grbrown's Avatar
grbrown
Wink
Thanks for that, they are even cheaper on Ebay.
Old Jan 11, 2012 | 06:05 PM
astark's Avatar
astark
Went with the Tayor/Sumax 2 guage cables I was considering and linked to on page two of this thread.
These are great cables, they work great, and I am very happy with them.
Thanks
Old Jan 13, 2012 | 08:00 AM
galtjunk's Avatar
galtjunk
With battery cables, size is almost everything.
I made a set of 00 battery cables for my 4 banger pickup truck.
When I turned the key, that starter spun. It didn't know that the battery wasn't an internal part of it.
Bodean46
May 17, 2014 09:40 AM
blacksportster05
Jun 28, 2011 10:14 AM
Jukebox
Sep 24, 2010 05:40 PM
DADDYO
Oct 25, 2008 05:08 PM
HDF Tech
Electrical/Lighting/Alarm
Jun 29, 2005 11:02 PM
