Unless you're riding through a dust bowl the entire distance, I wouldn't worry about it. Just bring that extra quart to keep it topped up and change it when you get back.
I agree with the others, Graham. 2,500 miles is an absurdly short oil-change interval for a top-quality synthetic oil like Mobil 1. Syn oils do not lose viscosity and shear nearly as quickly as dino oil does. A good synthetic like Mobil 1 or AMSOil MVC 20W-50 (which is what I run in all of our bikes) can easily go 5000 miles and have PLENTY of life left. There is a lot of research available on the internet discussing the longevity of synthetic oils.
If you really don't want to have to go in somewhere on your travels and get an oil change, I would just carry an extra oil filter, and change it at 5000 miles if you go over that on your trip, and keep the same oil in the engine.
As long as there is some in there to the correct level its fine .I don't know why everyone acts like if you go 1 mile over the recomended interval your oil instantly turns into clover lapping compound and destroys your bearings on the spot.I'd change it before the trip ,keep an eye on it during the trip , and change it when I got home.
I checked my S&S workshop manual before posting, to confirm the 2.5k oil changes, but didn't check my Harley one, otherwise I might not have posted! It has always seemed odd that S&S should call for shorter service intervals than H-D, but while it was under warranty and having cost me a fortune to buy and install it, I wasn't going to deviate from their schedule.
Thanks for all your replies, I can see the way ahead now - just get on and do it. I haven't come across any dust bowls in Europe yet, instead we have the prospect of crossing several mountain ranges, including the Transylvanian Alps - but not at night!!!
Reason: Grammar!
Have you ever had your oil tested? That alone might answer your longevity question. One thing that would cause oil to need to be changed is excessive gas in the oil .It tends to dilute the oil and lower the grade. Maybe at your next change catch a sample of what oil you normally use and send it off. That should tell the condition of the oil , flashpoint, and the tbn. A low flashpoint will cause higher oil consumption. Most oil when new will have a flashpoint over 400 degrees f. Gas in the oil will lower that number and cause consumption, as well as not giving the best lubricating quality. The tbn is how much life is left in the oil, based on remaining additives and dilution. If your using mobil 1 synthetic oil and your bike is in top shape, you'll probably be surprised how long you can really go with that oil. Oil testing is not slanted towards one brand or the other, just what holds up and what doesn't.,,
I emailed S&S and you won't be surprised that they say our planned trip will be fine and we can use any oil intended for air-cooled engines. So we can all relax. Thanks for your input and apologies for throwing a rock into still waters!
All good mate, you gotta question these things otherwise you may ruin you holiday by either worrying about your oil or getting an oil change done in the middle of nowhere and taking a chance on what they put in there....
