Jet Size Question
Old Jan 25, 2012 | 11:49 PM
mkguitar's Avatar
mkguitar
have a look at the number on the needle- the jet size is 1/2 of the equation
Mike
Old Jan 26, 2012 | 02:07 PM
Spanners39's Avatar
Spanners39
People think the main is not important because you don't spend all your time at 3/4 throttle but they are forgetting that main jet size impacts on the needle mixture too, also, if one day you decide to go flat out just for ***** and giggles you could melt a piston in less time than you might imagine. The main jet gets used a lot when hauling your old lady and luggage, especially up hills.
Jetting is holistic, you need to review the whole set up and not make uninformed assumptions.
Old Feb 5, 2012 | 09:12 PM
Dally-44's Avatar
Dally-44
Got the new Samson exhaust in this weekend and installed it.
I had to remove the support for the stock rear header.
Just waiting on some more parts for the carb.
Attached Thumbnails Jet Size Question-img_0149.jpg   Jet Size Question-img_0147.jpg
Old Feb 23, 2012 | 10:21 PM
Dally-44's Avatar
Dally-44
I ended up ordering a cv products kit. I put in a 45 slow and a 180 main. I am at 3500 feet above sea level so I didn't want to go too rich. When I pulled the old needle out it had three shims. Was that stock or from a previous owners mods maybe ?
Old Apr 10, 2012 | 09:23 PM
Dally-44's Avatar
Dally-44
I ended up with a 45 slow and 180 main, put everything back together about a month ago and fired it up no problems...
When I turned it off I smelled gas so I pulled the AC backing plate off and the half brass half plastic inlet 90 to the carb was cracked.
I just got the 1 piece brass in a few days ago, went for a ride today. Runs pretty good and the Samson pipes sound nice.
There is quite a bit of "popping" when I let off the throttle or decel.
Any ideas?
Old Apr 11, 2012 | 03:07 AM
badcooky's Avatar
badcooky
Some popping on decel is good ,banging and exploding is not.
If you want to get rid of the popping go out on the fuel mixture screw a 1/4 of a turn at a time till it's gone. They pop when you chop the throttle because the carb works only through the pilot and I reckon it should burble and pop a little or it's too rich.
badcooky's Avatar
badcooky
Sorry double up.
mmzullo
Sep 11, 2017 08:19 PM
buckmc
Carburetor Related
Nov 28, 2008 07:43 PM
aa961jester
Exhaust System Topics
Aug 27, 2007 08:51 AM
outfishin35
May 30, 2007 12:19 PM
Gadgetech
Aug 27, 2006 03:35 PM
