1990 evo plugs
Old Mar 9, 2012 | 11:10 PM
machinehed's Avatar
machinehed
Default 1990 evo plugs
Hi all.
Have a newly purchaced 1990 FLT ex. police with 160000 klms.
Havent had a chance to get to know her yet as winter was upon me and no garage etc.
Did pull the plugs and noticed heavy black sooty deposit on both.?
Any opinions. ???
Old Mar 10, 2012 | 02:29 AM
RidemyEVO's Avatar
RidemyEVO
Yes replace with new ones.
Old Mar 10, 2012 | 11:10 AM
Johneblast's Avatar
Johneblast
I'm running E3-34 plugs right now and they seem to run a little on the hot side. Went to the dealer and got a set of 5R6A's to see if they run colder. Just some suggestions. My bike is fairly stock.
Old Mar 10, 2012 | 11:39 AM
oppirs's Avatar
oppirs
Good idea to change them even if they don't look worn.
I put a set of Autolite 4265 in last year, made start-ups very easy! My ride really likes the Autolites USA made.
Old Mar 10, 2012 | 12:36 PM
RidemyEVO's Avatar
RidemyEVO
Changed mine to the auto lite last year and they seem to do quite well, rear plug a bit darker but that seems to be normal.
Old Mar 12, 2012 | 09:05 PM
machinehed's Avatar
machinehed
Thanks to all for the replies but ... aside from the plug makes etc.
Would i be possibly looking at a carb. set too rich or whatever .?
I think the po rode it to work and back in the last few years of ownership .???
If the plugs are this carboned up , i have to assume the heads are too .?
What would you recommend here boys ...?
Old Mar 13, 2012 | 07:51 AM
RidemyEVO's Avatar
RidemyEVO
Hard to say, if your getting run on the heads could be carboned and also if po had a short run to work and he ran with enrich enter on that could blacken the
Plugs. Try a new set and see how they look after a good run after keeping the mph low which would keep your carb in the pilot jet range.
Old Mar 13, 2012 | 08:36 AM
omgtkk's Avatar
omgtkk
I wouldn't put much value in reading the plugs on a bike that you just bought and has been sitting. Prior owner may have done nothing more than start it and let it idle every few weeks.
Change the plugs and all the fluids. Give it a thorough looking-over. Then take it out and ride it for a few hundred miles to assess how she runs.
Enjoy first, worry second.
Old Mar 14, 2012 | 07:03 PM
machinehed's Avatar
machinehed
Plugs are plugs as the ole saying goes , but the newer plugs are really good .
Would like to try a set of irridiums in the ole 1990 evo.
Anyone know what the proper cross over # is ?
Old Mar 15, 2012 | 12:45 AM
Joboo1966's Avatar
Joboo1966
There's a banner atbth bottom of the plugs they should have the crossover #
