charging problems
Old Mar 12, 2012 | 12:20 AM
badcooky's Avatar
badcooky
Originally Posted by jeffreydsilver
A 12.37 volt reading is a DISCHARGED BATTERY! At rest the battery should read 12.9 volts, fully charged. A 12.7 volt reading is a 25% discharged battery. KISS - Keep It Simple Senor!
Not if there's a short somewhere.
Old Mar 12, 2012 | 06:49 AM
jeffreydsilver's Avatar
jeffreydsilver
Originally Posted by EVOrider
I am showing 12.37 at idle.
12.37 volts is 12.37 volts WITH OR WITHOUT A SHORT! Don't confuse volts with amp draw. The first step in diagnosing a charging system is to check the battery first. Volts have to be up to snuff before load testing (controlled amp draw).
Old Mar 12, 2012 | 04:31 PM
EVOrider's Avatar
EVOrider
The battery checked out ok....
The output at the stator should be 19-26 at 1000 RPM. The output I am getting is only around 10. According to the manual, it could be the stator or could be the rotor. I wish I knew exactly which one was bad.
I am going to order the stator and cross my fingers the rotor is still ok. Both items were OEM Harley and were installed about four years ago. I just can't see the magnets coming loose just yet.
Old Mar 13, 2012 | 09:25 PM
dhbmedic's Avatar
dhbmedic
Default 98 Ultra charging problem too ...
Just read your posts. Funny, I have EXACTLY the same problem on my '98! I bought the bike about 2-1/2 years ago with ~33K on it, just turned 53K today.
Short version: Looked at the fairing voltmeter this morning (more than halfway to work), and it read 10V!! On the way back I stopped by the dealer to get a new battery (2005) and a new voltage regulator. Battery ran out completely just as I pulled into the parking space! Put the new battery in at the dealer, came home & Did the static stator tests (no short, good resistance) then replaced the regulator - an upgraded part from original, I think. Cranked it up - DAMN! Dash meter at ~11V or so ... Next checked the AC, only about 1A per 100RPM (10A at 1000, 19A at 2000, etc.) Crap.
Longer version: Over the past couple of weeks or so I noticed the voltmeter dead nuts on at 12V. Before that there seems to have been quite a bit of fluctuation in the readings: drops when brake lights on (I have the light-em-up rear TourPak lights), up-and-down with the turn signals, stuff like that. In the bad old days, at least with my 67 Mustang Fastback, this was a dead giveaway for the regulator.
So now I know it's not the regulator OR the battery, my wallet is now about $400 lighter, and I'm heading into the rotor & stator.
Any ideas out there about which of these to replace? Anything else I should replace while I'm in there? And do I need this "ROTOR REMOVER/INSTALLER and SHAFT PROTECTOR SLEEVE" ?? OEM or after-market parts?
I'm learning WAY more than I wanted to about repairing this thing, but at $4.50/gal and 40+ mpg I'm thinking it's worth it. Maybe.
Old Mar 14, 2012 | 05:45 PM
EVOrider's Avatar
EVOrider
For the rotor.....if all the magnets are still intact, then it is fine. When you have it apart, it will be obvious the stator is bad....such as burnt odor from primary.
Always use new stator screws and there are four of them. You don't need the rotor removal tool.....a steeing wheel puller works just fine with spacers. You also don't need the shaft protector either.....duct tape works just fine. You also don't need the primary lock....nearly anything will lock the primary.
I would go with OEM from Harley or Cycle Electric.
For mine, I have a new stator plus the screws ready for installation. I did not get the rotor just yet....as I am assuming the rotor is fine.
Old Mar 16, 2012 | 04:55 AM
EVOrider's Avatar
EVOrider
Got mine all torn apart and I was right. The primary fluid smelled terrible! The stator was partially burnt in certain places. I was going to install the new stator, but the plastic holddown was cracked in the middle. Now, I've got to pickup one of those now.
I've just never seen a stator that was partial burnt and would still work once the RPM was around 2000. From my experience, they either charge or don't charge....so this was a first for me.
Old Mar 19, 2012 | 06:32 PM
EVOrider's Avatar
EVOrider
I just wanted to add.....
I was having radio/intercom problems. The radio would not shutoff if you spoke into the intercom. Same goes with the passenger including the CB. Basically, if you wanted to speak to someone, you had to speak over the radio. It was annoying!
Once I replaced the stator, all was good and the radio/intercom functions correctly.
Anyways, if you have radio/intercom similiar problems I was having.....suspect the stator is going bad.
Old Mar 20, 2012 | 09:18 PM
dhbmedic's Avatar
dhbmedic
Got it all apart, stator doesn't have that burned smell, but all the magnets in the rotor are bunched up together, with big holes between some of them. Damn!
I've already put the new OEM regulator in. Should I stick with OEM, or can I go with aftermarket stator and rotor? Will try to upload photo if I can figure out how with iPad / iPhone.
https://www.facebook.com/photo.php?f...8&l=649effed4f
Old Mar 20, 2012 | 09:45 PM
Mountainkowboy's Avatar
Mountainkowboy
I was told that the HD units seem to last the longest.
Old Mar 20, 2012 | 11:12 PM
RidemyEVO's Avatar
RidemyEVO
Dhbmetic you just have to make sure what ever you use the amps have to match. I'm not sure how many amp system you have now but I put a 38 amp cyclelectric and never looked back.
