charging problems
Old Mar 10, 2012 | 05:42 PM
EVOrider's Avatar
EVOrider
Default charging problems
I started the '98 Ultra and was getting ready to ride. Then, I noticed the system was not charging according to the fairing gauge. I just rode yesterday for 100 miles with no problems. Strange how something could quit while just sitting there.
The stator checked out ok with no continuity and it was less than 0.5 ohms.
The AC output at idle was about 10 VAC where it should be 19-26. However, at higher RPM such as 2000, then it is charging.
Last charging problem I had was when it would not charge at all. The culprit was the stator shorted out. This time is different.
I've replaced both items about six years ago with Harley OEM with about 20,000 miles since.
So, what's going on....stator or rotor? I'll check the regulator later as the load tester is at a friends house.
Old Mar 10, 2012 | 05:51 PM
Mountainkowboy's Avatar
Mountainkowboy
I would say most likely a stator, if you lost the magnets on the rotor they would be bouncing around the inside of the primary making a hell of a racket.
Old Mar 10, 2012 | 07:16 PM
razors edge's Avatar
razors edge
put a meter on the battery and doudle check your guage.
Old Mar 10, 2012 | 07:19 PM
razors edge
i re read your post, you obvisoly have a meter.
Old Mar 10, 2012 | 07:24 PM
Bleachey's Avatar
Bleachey
It may be a moot point, but I always start simple, did you check the battery? My gauge wasn't reading a full charge, I went through the tests and it was the battery
Old Mar 10, 2012 | 09:08 PM
EVOrider's Avatar
EVOrider
I'll be getting back my load tester from my friend either tomorrow or the next day. I'll have a better check on the battery at that point.
With the Fluke multimeter....I am showing 12.37 at idle. Increase idle, and the volts increase accordingly up around 14 or so. This does show it is charging...previous tests already confirmed this.
The battery could be a problem....probably closer to fours old now. Only the load tester can test this accurately.
It still didn't pass the AC output per the manual.
I'll know in more in a day or two.
Old Mar 10, 2012 | 09:37 PM
badcooky's Avatar
badcooky
You'll have to do an open and a grounded stator test to know more,I'm not sure of your year as a few readings are different.
Old Mar 10, 2012 | 09:45 PM
Kabear's Avatar
Kabear
Sounds like the fairing gauge is faulty.
Stator should put out 20v a/c per 1000 RPM.
DC voltage sames about right.
Old Mar 11, 2012 | 09:53 AM
EVOrider's Avatar
EVOrider
Among browsing the internet....Wondering if this could be applied to the EVO EFI models as well. I know I've gone through several stators with my Ultra and they were all Harley OEM.
http://www.pvc.maricopa.edu/~preston/29987-99a.html
Old Mar 11, 2012 | 10:04 AM
jeffreydsilver's Avatar
jeffreydsilver
Default Kiss
A 12.37 volt reading is a DISCHARGED BATTERY! At rest the battery should read 12.9 volts, fully charged. A 12.7 volt reading is a 25% discharged battery. KISS - Keep It Simple Senor!
