checking oil
Old Mar 11, 2012 | 07:09 PM
hotrod351's Avatar
hotrod351
Default checking oil
this has been a problem for a long time. if i check my oil after my bike has been sitting for a couple days or a week it will always show low, not empty but a little low. if i top if off i always end up with a oil leak from my sprocket shaft seal, i have a bdl open belt drive. not to much of a leak, just a drop or two. now if i go for a 20 or 30 mile ride and then check my oil it will show full. what ive started doing is if my oil is down 1/3 of a quart i just go ahead and then it shows full. now doing it this way i dont end up with any leaks. i can do this after my bikes sits for a week or two and i get the same results, no leaks and the oil will show full. its not dumping out the sump tube. i figure some how the oil is getting back in the engine, oil pump check ball, then when riding it gets pumped back out. guess as long as i dont get any oil pumping out ill just call it good. it is nice not to have any leaks.
Old Mar 11, 2012 | 07:14 PM
Mountainkowboy's Avatar
Mountainkowboy
Oil level should ALWAYS be checked at operating temp, that is the only true oil level.
Old Mar 11, 2012 | 08:35 PM
hotrod351's Avatar
hotrod351
thats what i finally found out. sure is nice to not have any leaks. it makes me look forward to the laughlin run next month.
tim selock
Dec 31, 2020 07:28 AM
Pale Horse Rider
Jan 15, 2015 12:05 PM
PewterHeritage
Aug 30, 2009 10:14 AM
slinky9_99
Exhaust System Topics
Apr 11, 2006 02:45 PM
Anthony8858
Oct 2, 2005 09:51 AM
