OK, so I think I'm getting the dreaded "click"
Old Mar 22, 2012 | 04:29 PM
traildog's Avatar
traildog
Default OK, so I think I'm getting the dreaded "click"
Every so often, when I hit the stater button, nothing.......then I hit it again, and she turns over. It this the "dreaded click" I see being discussed?
Sometimes, the starter sounds "crunchy" like gears aren't meshing properly.
What the heck should I do.....She came with a "no haggle" warranty......at least it I think that's what NGH meant when he said "as is."
Old Mar 22, 2012 | 04:32 PM
traildog's Avatar
traildog
heck with it, I'm having
Old Mar 22, 2012 | 05:47 PM
SportsterBob's Avatar
SportsterBob
I had the same issue and it was the starter solenoid. After removing the starter and doing an inspection, the contacts looked like the surface of the moon. Pits and craters everywhere.
Old Mar 22, 2012 | 06:35 PM
traildog's Avatar
traildog
Solenoid.....I think I'll try a new one and see what happens,,Thanks.
Old Mar 22, 2012 | 06:40 PM
schwangster's Avatar
schwangster
check all your connections and grounds. If the battery cables are lose, you lose a lot of juice to the starter.
Old Mar 22, 2012 | 07:14 PM
Dr.Hess's Avatar
Dr.Hess
The Dreaded Click is a big Click or Clunk and nothing else. If you don't get that much, then you have a related but not identical problem. If you push the button and get nothing at all, not even a Clunk, then I would look at the starter relay or the starter switch in the handlebar (which rarely go out).
Old Mar 22, 2012 | 07:26 PM
FlamedFXR's Avatar
FlamedFXR
I go through at least 1 starter relay a year, cheap fast fix. Its a very faint click and you may have to hit the starter button 4 or 5 times before it engages the starter.
Old Mar 23, 2012 | 08:21 AM
Bama91's Avatar
Bama91
Also check the small wire off the solenoid (it goes to the relay). I have seen a few bad connections on these.
Old Mar 23, 2012 | 10:29 AM
traildog's Avatar
traildog
Sir, I owe you a cold one.
Took the seat off and hit the starter........the positive cable was so loose, it was arching, the negative cable was loose also.
Tightened them both as hard as I could and wowee! Turned over and started faster than I've ever seen!
Thank you sir.......
Old Mar 23, 2012 | 10:46 AM
schwangster
You're welcome.
Been there, done that. Tightening the battery connections is on my regular maintenance list.
