1986 FLHT 80 inch compression?
Old Mar 25, 2012 | 08:31 PM
CycleNaz's Avatar
CycleNaz
Default 1986 FLHT 80 inch compression?
HEY OUT THERE...anyone lend a hand and lemme know what the compression should be for both cylinders on my 1986 EVO...thanks a ton and STAY UP
Old Mar 25, 2012 | 09:50 PM
Gunslingertom's Avatar
Gunslingertom
Book says 90 psi
Old Mar 26, 2012 | 06:27 AM
RaSh's Avatar
RaSh
Default Compression
This will be interesting.
I have a '89 FLHS, EVO of course which has a factory compression of 8.5:1. I took 14.7 PSI x 8.5 = 124.95 PSI as a reference, checked my compression myself, and also had it verified by my indie, and obtained 125 PSI both barrels, both times, and I thought "GREAT!"
However in a couple of on-line discussions I learned of other standard compression bikes (At least that's what I believe.) with much higher readings (200 PSI ą 20PSI) and was told that this had to do with cam timing/valve overlap, etc.
I'm still not comfortable with my understanding of the way that it all works, and with the values reported, so this may lead to a better understanding for many of us. Looking forward to the replies.
To sort of answer your question, I now believe that my compression values are low, but since they are even I'm O.K. for now. I am planning for a top end rebuild after this riding season so it's all relative. I'm led to believe that the results of a leak down test indicate a slight valve issue is the prime suspect, but intend to clean up everything cylinder /head related once it is broken down for headwork
Old Mar 26, 2012 | 07:55 AM
tc's Avatar
tc
As Gunslingertom says 90psi or higher is stated as normal in the Harley manual with a difference of no more than 10% between cylinders.
Make sure choke and throttle are wide open and crank engine 5 to seven times.
TC
Old Mar 26, 2012 | 08:18 AM
CycleNaz's Avatar
CycleNaz
My compression is around 140 on both holes for my 86 FLHTC stock everything....so i was told 120-150 is good by my buddy NOOT for my pan/shovel which is tested at 120 on both holes...
Old Mar 26, 2012 | 08:22 AM
CycleNaz's Avatar
CycleNaz
i was talking with my buddy noot and he was talking about the same concept with cams...i cant remember which cam he mention i thought it was a sifton which makes either lower or higher compression readings....not sure which is which...when ever i talk to Noot he has a bout a million things he tells me to try which is extremely helpful, but the other small talk is forgotten due to the fact im trying to remember every detail he told me about testing this and that.....hahhaha
Jim Anderson
EVO
Sep 23, 2024 09:57 PM
DeneFXDWG
Exhaust System Topics
Apr 22, 2019 05:10 PM
jhnmflr
18
Oct 16, 2009 07:23 PM
HD Attitude
Dec 3, 2007 04:53 PM
bluezguy
Shovelhead
Jul 27, 2006 12:33 PM
