what to do?
Old Apr 6, 2012 | 08:33 PM
hangin iron's Avatar
hangin iron
Question what to do?
i have 98 electra classic. the rear jug has slightly spun counterclockwise about a sixteenth inch. its weeping a little oil.at 95000 a reman was installed it now has 115000.in july i plan on a 3000 mile trip midwest, should i do a total breakdown or loosen jug put it back and retourqe?????
Old Apr 6, 2012 | 08:40 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You cannot loosen the jug and reposition it.
You must remove the cylinder, replace the base gasket and reassemble.
Make sure the cylinder hold down studs are not loose or pulled out of the case.
Is it still under warranty?
Old Apr 6, 2012 | 10:45 PM
msgtarmor's Avatar
msgtarmor
Yes, fix it before you go.
jim
Old Apr 6, 2012 | 10:53 PM
Joboo1966's Avatar
Joboo1966
This ic correct......postpone trip until it can be fixed properly......
Old Apr 7, 2012 | 06:18 PM
hangin iron
Default what i did
no warranty that i would know of i checked head bolts the 2 bolts on spark plug side were easily snugged prob about 40 lbs the other side under rocker cover pretty tight
Old Apr 7, 2012 | 08:39 PM
hangin iron
Default thread check
checked some search threads most said ride it till ready to do some mods. i might just try that and next winter maybe a little bore and cam might be in order. but i do appreciate everyones thoughts. if anybody had experience in drastic failure let me know
Old Apr 7, 2012 | 08:57 PM
msgtarmor's Avatar
msgtarmor
Hopefully, you wont have one!
Good luck..
jim
Old Apr 7, 2012 | 09:04 PM
RidemyEVO's Avatar
RidemyEVO
Mister this is only April 7 and your not trippin until July 1, do a top end build and double check you didn't pull any studs. I keep a spare set of gaskets on my wall and have done a tear down overnite for next day trip, you have plenty of time.By the way I have experienced pulled studs and now keep a dozen time-serts in my tool box for the next time one of my buddies have this experience.
Old Apr 8, 2012 | 07:17 AM
Dan89FLSTC's Avatar
Dan89FLSTC
RidemyEvo hit it on the head, get it done and then no worries. It is a simple job.
Old Apr 8, 2012 | 07:46 AM
hangin iron
i read another thread that had a book called 101 improvements that is easier to read than the service manual that i have when i read my manual it seems to jump around to many diff types see fig 16 for this year see fig 18 for that year. ive rebuilt jeep engines but never bike so i think i was a little overwhelmed reading that foreign language
