Regular gas???
Old Apr 10, 2012 | 08:01 AM
Doug S's Avatar
Doug S
Traildog,
I don't know enough to explain it well but since I started this thread I've been doing some research...take a look at wiki, it explained it well and I'd only be repeating what I read there last night ...LOl
http://en.wikipedia.org/wiki/Engine_knocking
Doug
Old Apr 10, 2012 | 09:03 AM
Doug S's Avatar
Doug S
Without getting into a big long speech, the lower the octane you can run without getting into detonation the better, 87 is volitale and burns quicker than 93.
Well, last night I got the big long speach from a good friend who is also an excellant car mechanic, he said the same thing and explained it, never knew that.
I also never read the manual, mine says "atleast 87octane", I just always put premium in because everyone said so. I have no idea what my compression ratio is, the PO put a cam in and had head work done. This bike pulls much harder than my last EVO which was a stage 1 -1999 FXSTC.
Kushman noted that his regular is not corn gas, I'd like to find out what ours is but it's hard to find a gas station attendant who speaks english. I'm going to call the state today and find out what we have and if it changes through out the year.
Another question:
I've noticed in many threads that guys are running 48-50 and 180-190 jets on bikes with just a cam and I wondered how they get away with it and not run rich? I'm running 45/165 with 1or2 washers under the needle, idle screw one turn out and my plugs show a very slight rich condition-40/42mpg-plenty of power with no flatspots and I never need WOT-(it's pretty fast for what it is).
Thanks for the responces, I'm learning something..
Doug
Old Apr 10, 2012 | 10:22 AM
gsxrboy96's Avatar
gsxrboy96
Another question:
Doug
Doug. There are a lot of variables to jetting such as motor mods, exhaust, altitude, emulsion tube, type of needle, and so on, with that said. Such jet kits as dynojet pull more fuel off the needle than the main, so you actually run a smaller main than if you ran a stock tube/needle, I'd suggest that you find whats right for your bike and use that, just my two cents . Chad
Old Apr 10, 2012 | 12:26 PM
miacycles's Avatar
miacycles
There are so many variables in the stock Harley production engines. That is why some engines like regular and some don't. Add to that carbon build up, engine wear, riding style, one-up/two-up, and gearing along with all the other variables, some engines will ping and some won't. Now for the kicker----if you fuel up at a station that has only one hose you are getting almost a gallon of whatever was pumped last, which is usually regular. If you only take three gallons of fuel, two are 93 octane and one is 87 octane for a blend of 91 octane. So you are only running mid grade!!!!!!!
Don't forget different areas of the country have different blends and they also change with the seasons too.
Old Apr 11, 2012 | 06:22 AM
shoemaker's Avatar
shoemaker
Shhh! Don't tell the missus.That's why I always fill hers first.She just thinks I'm being polite.
Old Apr 11, 2012 | 08:20 AM
miacycles's Avatar
miacycles
Me too if the only place we can find has one hose!!!! :-))
Old Apr 11, 2012 | 08:28 AM
Bleachey's Avatar
Bleachey
Please excuse my ignorance but I would like to know if EFI/Carb would have any impact on the type of fuel needed?
Old Apr 11, 2012 | 11:16 AM
Doug S's Avatar
Doug S
John,
I can only find one supplier in my area that still uses separate hoses and when I ran only premium I went out of my way a little to go there. Since I'm running regular I can go anyware because odds are the last vehicle use it.
Doug
Old Apr 11, 2012 | 11:35 AM
miacycles's Avatar
miacycles
Carb or EFI won't make a difference as long as both are tuned properly.
Old Apr 11, 2012 | 01:13 PM
RidemyEVO's Avatar
RidemyEVO
Last year I ranthe highest grade in my bike and my wifes 99 sporty. If I ran the lowest in her sporty she would get run on. If I ran the lowest in mine it didn't seem to make a difference. This year she has the 89 heritage so we shall see.
