Regular gas???
Old Apr 9, 2012 | 10:13 AM
Doug S's Avatar
Doug S
Default Regular gas???
Hi,
Just wondering what your thoughts are on running fuel other than premium? Ever try it, any issues?
Found out a few weeks ago that my petcock was not working , when I ran out of gas and had no reserve....LOL. Nice homeowner gave me his old lawnmover gas and the bike ran fine, really good actually. So I put some fresh regular in, no pinging, no loss of power I could tell, it runs better-(less fat)- at slow speeds and I've never heard it idle so well. Ran a couple of tanks so far and yesterday I put in a few gals of mid-grade and it's Ok also. I figure I'll need to go to premium in the hot weather but I'm liking this right now...
Thanks
Doug
Old Apr 9, 2012 | 11:27 AM
rscalzo's Avatar
rscalzo
That might not be the case when it gets hot and under load or higher altitudes.
Old Apr 9, 2012 | 11:51 AM
SIDECAR BOB's Avatar
SIDECAR BOB
been running regular in cooler weather also, around here a lot of the regular is not ethanol enhanced. Seems to like the no alc more than the 1 or 2 point higher octain
Old Apr 9, 2012 | 12:00 PM
Kushman's Avatar
Kushman
Hey Doug,
I do not use regular up here (Canada) most fuel below premium can have up to 10% Ethonol that from what I understand from previous threds can cause issues due to attraction of water. Not sure what the policeis are down there? Could the ping be a jetting or timming issue?
Old Apr 9, 2012 | 12:17 PM
carlgrover's Avatar
carlgrover
I've ran a tank or two of regular in mine. It vibrates more. Doesn't really like it. This is the 10% ethanol junk.
Old Apr 9, 2012 | 12:37 PM
Shredding rubber's Avatar
Shredding rubber
Regular is fine in a stock bike. If you had more compression or timing advanced then you may want to run higher octane.
I have run regular in my 96 with no issues however here in Saskatchewan premium isn't polluted with ethanol so I get a bit better mileage because of it.
Old Apr 9, 2012 | 01:01 PM
the blob's Avatar
the blob
I've been running reg. Gas in my stk. Softail with no probs
For a couple of years now. No pinging either. I just figure
With an 8.5 to 1 comp ratio premium is a waste.
Old Apr 9, 2012 | 01:22 PM
dirtyharryfxrt's Avatar
dirtyharryfxrt
My FXRT only runs on premium but my Sportster like regular.
Old Apr 9, 2012 | 04:00 PM
big cahuna's Avatar
big cahuna
My '96 has a factory sticker on the downtube that says to use 87 octane gas in it. So I do, runs fine.,,
Old Apr 9, 2012 | 04:41 PM
a10182's Avatar
a10182
I always just run premium, I dont plan running regular unless I am desperate for gas
