Intake leak
Old Jun 5, 2012 | 07:55 PM
Glider rider's Avatar
Glider rider
I changed mine to a solid intake. No more leaks.
Old Jun 7, 2012 | 09:41 PM
Edster 69's Avatar
Edster 69
So I bought intake seals from HD and have an appointment with my Indy to change them out tomorrow.
Tonight I decided to siphon out the gas from my tank so I could check my filter from my petcock to make sure it is clean and to rule out that it isn't part of the equation for my bike to backfire on deceleration and my spark plugs to be white.
I siphoned the gas into a glass jug and as I get to the bottom of my tank these off white transparent like flakes start showing up in the jug?? Wtf?? I take off the petcock and check filter and there is a little bit of the same stuff??
Any one know wtf it is?? Input would be appreciated!!
Old Jun 8, 2012 | 05:52 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You would be better off starting a new thread for each new question.
That said do you know if anyone ever put that cream tank sealant stuff?
The old style cream will come off with the new ethanol gass.
Old Jun 8, 2012 | 06:24 AM
Edster 69's Avatar
Edster 69
THC your right I should of started a new thread! I'm the second owner but what you wrote makes sense. Thanks for your input!
Old Jun 8, 2012 | 06:42 AM
texashillcountry
Dirt don't hurt
While you have your bike at the indy's you should have him check out the tank and see if that is your problem.
Old Jun 8, 2012 | 10:29 PM
Uncle G.'s Avatar
Uncle G.
I watched a mechanic change the manifold seals on my Softail. As I remember, it took him something like 15 minutes. I've done it myself on my Sporty and it took less than an hour (I don't have as much practice). On the Sportster, I didn't need to remove the tank.
Old Jun 9, 2012 | 04:08 PM
Edster 69's Avatar
Edster 69
Got my bike back from my Indy and my ol'girl is good to go! Two hours of labor, intake seals, new front master cylinder, brake oil, cleaned carb and adjusted the timing $250 all in!!
Sturgis here I come!!
Old Jun 9, 2012 | 06:14 PM
Dr.Hess's Avatar
Dr.Hess
Have a beer for me. I usually stay at Hog Heaven. Don't think I'm going this year. I'm taking a couple years off.
Old Jun 9, 2012 | 06:27 PM
pigbike's Avatar
pigbike
Just had the intakes on my 2005 twin cam and it was 140.00 bucks total at a Indy. He had to stuggle with one bolt he said. It also has a engine fan and is FI. This included new flanges along with the intake gaskets. Sounds about in line with your bill, as you had the master cyl. also.
cuda67bnl
Exhaust System Topics
Apr 20, 2022 07:32 AM
skinman13
Mar 25, 2018 01:31 PM
94 lr
Jul 13, 2013 11:17 AM
dvsf100
May 21, 2011 12:59 PM
HDF Tech
Engine Mechanical Topics
Jun 24, 2005 06:33 PM
