Carb vs f.i.
Read the EFI section dudes.
EFI breakdown is a 1 in 50,000 experience I bet. That's like being afraid of riding because you might get a flat in 10 or 20 years.
Carbed bikes don't have fuel pumps? Gravity feed only? Not for all those super-reliable carbed cars, right? Also the part about any one bad sensor = tow truck is false too.
With an autotuner, its much more friendly.
Ok going to pull out the wildcard, M&M duel runner throttle body design just plain out sounds like ****! split mine, removed the divider and got the M&M to sound more like a Harley, couldn't take Italians simulating the japanese sound anymore.
In addition, the MM system is open loop in terms of AFR, but temperature and barometric pressure are dynamically controlled--Which you allude to here:
I know in my industry, everyone is trying to run ITBs on everything, but they're completely out of their minds.
Now, in terms of full load performance, Open loop vs closed loop doesn't even have a role. The Delphi system (Along with just about every EFI system on the market) goes to open loop at about 40% throttle. The only issues I have ever had relate to low speed operation.
Now, if you guys think HD is "Lagging behind" the automotive industry, in terms of engine management, you'd be barking up the wrong tree. HD has several patents related to Ionization feedback detection, so in addition to all the usual parameters read by the ECU, it also factors in the efficiency of the combustion process and can control spark parameters accordingly.
So, is it easier to get more HP from a carb setup, Of course--particularly when you don't have the resources to design an efficient EFI system.
Is the current Delphi system better than the MM system? Of course, it's actually revolutionary. But we're comparing state of the art to an OBDI era system.
Would you not buy a car because it was OBDI?
Good stuff Gary!
In 07 Garret had a turboed Road King at SEMA. I came home with pictures and studied up about how to do it on mine.
I was just going to use the MM hard parts and reconfigure some AEM EMS system to handle the ECU duties.
Then I hauled a tent, sleeping bags, clothes and groceries across a fair piece of Canada and it ran so flawlessly I decided not to poke at it.
Great technical comparisons, and most civil presentation.
Proud to be an EVO rider.
I would like to add one tiny and insignificant personal opinion, if I may:
My S&S Super E is just plain sexy!
Would love the DaVinci polish job on her, but she's still gorgeous in stock form.
Three screws I can play with, right out in the open!
And the satisfaction when get it right.
Anyway, carry on. Great thread.
I wonder if and when Harley will go to direct injection allowing higher compression ratios due to the cooling effect with even more power and mileage?
Your question of DI has actually been part of my point regarding the moco's lag.. DI definatly has its advantages. It does in fact create a cooling affect and with wide band o2's, it can make adjustments on the fly for proper AF ratio under nearly all opperating modes, including WOT, even with forced induction... If they intend to remain air cooled, making this step could be very bennificial.. EFI is a wonderful thing if it is used to its potential..
