Cleaning the ignition switch?
Old Jun 8, 2012 | 07:08 AM
traildog's Avatar
traildog
Default Cleaning the ignition switch?
Anyone ever heard of cleaning an ignition switch to get it functioning again?
I took a look at mine last night, and it seems to me, there's not too much that can go wrong with them.
Old Jun 8, 2012 | 08:43 AM
miacycles's Avatar
miacycles
Go to an electronics store and get some contact cleaner. Make sure to use it in a well ventilated area.
jOHN
Old Jun 8, 2012 | 08:55 AM
crawford769's Avatar
crawford769
I cleaned the one on mine and it works fine now. Pretty simple.
Old Jun 8, 2012 | 04:31 PM
Spanners39's Avatar
Spanners39
You can scrape the crud off the contacts and that will work.
Old Jun 8, 2012 | 07:02 PM
Mr1986FLST's Avatar
Mr1986FLST
I've cleaned mine with electrical contact cleaner in the past, worked fine...if it is really bad you could probably use emory paper to scrape the connectors clean...
Once I had to replace the switch because one of the rivets holding down a conductor connection was loose and you could see where it blackened pretty bad due to heating from the poor electrical connection.
Old Jun 8, 2012 | 07:56 PM
traildog's Avatar
traildog
Thanks guys. I bit the bullet and paid the $107 for a new one.
I am going to try to clean this one and keep it for a spare.
Old Jun 8, 2012 | 09:15 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Spare parts are never a bad thing.
cajun1957a
Aug 11, 2023 02:53 PM
sixty7flh
Electrical/Lighting/Alarm
Sep 26, 2014 08:36 PM
two tall
Apr 1, 2011 01:22 AM
781/2fxs
May 13, 2009 11:24 PM
F1J1
Jul 14, 2007 07:28 PM
