Starter
Old Jun 12, 2012 | 07:42 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You need to go back and read the op`s post. His starter is turning, but the starter turns and then stalls.
If the starter is being energized, the relay is doing it`s job. Simple.
Take a look at the wiring diagram and you will see what I mean.
Damn I hate it when I screw up.
Dan I owe you an apology.
Old Jun 12, 2012 | 07:53 PM
oppirs's Avatar
oppirs
Originally Posted by grbrown
Best enjoyed on British tyres..........
I have run Them.... Not a duel tread.
Old Jun 13, 2012 | 04:32 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Not necessary...I screw up all the time.
Old Jun 13, 2012 | 05:44 AM
Schex's Avatar
Schex
I changed out a battery last year that was doing something like that,
It would reset the radio it pulled down so far when I started it.
It would kick in hard then drag on the first revolution or stop turning and have to release and hit the starter again.
The battery never went dead, I still use it around the shop to test lights and stuff.
Old Jun 13, 2012 | 06:34 AM
DANNER55's Avatar
DANNER55
I have had the same problem wth my 89FLT! On vacation in the Smokies & starter went out. Replaced the starter relay, but it didn't help. We ended up drilling a hole in the solenoid cover. Every time I needed to start the bike I just inserted a drift in the solenoid & pushed it in to start it.
Six days later we got back to florida with no problem!
I had the starter & solenoid rebuilt & six monthe later I had the same problem. So I bought a new starter from Surdyke & the problem went away for a short time & then it came back.
There is 2 ways you can fix your problem.
#1 Install a manual activated switch in the end of solenoid housing.
Starting from $100 from J&P Cycles.
#2 I fixed my problem by installing a ford starter solenoid under the seat.
This is a cheap fix & I haven't had anymore problems. This gets a true 12 volts to the starter.
#1 mount ford solenoid under the seat.
#2 battery cables need to be rerouted to solenoid & then to starter motor.
#3 The power wire from the relay to starter needs to be cut & hooked up to top of the ford solenoid. This is your handle bar button wire.
#4 The hot wire from your circuit breaker to starter need to be cut & hooked up to the "IN" side of the ford solenoid.
#5 Now take the other end of the wire in #3, put a large terminal connector on it & hook it up to the solenoid & then to the starter motor. This will be a short wire when you are done.
That's it your done! This fixed my problem & this has been about 2 years since I did this install.
Just a note. After doing this install you can no longer use a drift to activate the solenoid.
I hope this helps & good luck.
Summers420us
EVO
30
Feb 22, 2023 03:10 PM
BubbaFLMC
Shovelhead
May 6, 2019 07:47 PM
Donn 86 flhtc
Mar 4, 2015 07:42 PM
xwhyz1959
Nov 21, 2013 02:24 PM
hardheaded
Shovelhead
Jul 1, 2013 12:11 AM
