Starter gears grinding?
Old Jun 28, 2012 | 09:27 PM
Dyna7's Avatar
Dyna7
you know i am running a high compression engine, i am wondering if i need a high torque starter to get it to roll over also?
Old Jun 28, 2012 | 09:31 PM
RidemyEVO's Avatar
RidemyEVO
89 will have tapered shaft and 90 will have splined shaft, mine was changed to splined.You don't need to change basket, you only need to change ring gear. The teeth from jacks haft contact ring gear.
Old Jun 29, 2012 | 05:02 AM
Spanners39's Avatar
Spanners39
That and fat wires wouldn't hurt.
Old Jun 29, 2012 | 03:19 PM
Dyna7's Avatar
Dyna7
where could i get that gear from? i didnt know that one came off, i thought it was one solid piece
and Spanners thats not a bad idea with the fat wires, might be a good weekend job since the wifes at work all weekend
Old Jun 29, 2012 | 03:21 PM
Dyna7's Avatar
Dyna7
and also, since its obviously a different setup in there, how will i know a stock ring gear will fit that one?
were they all the same diameter?
Old Jun 29, 2012 | 03:56 PM
Dyna7's Avatar
Dyna7
i have been reading about starter kickback on high compression engines, i think the goal this weekend is to pull the starter and see if the engine has busted it to where it doesnt lock backwards, (also run a compression test to void out that problem and check for spark, hit the basics real quick), any good high torque starter ideas?
Old Jun 29, 2012 | 04:02 PM
Spanners39's Avatar
Spanners39
I am not sure about the ring gear diameter but it may be that you have a missing bush and that is all it is. You might already have a decent enough starter motor for your compression.....don't get distracted by speculation....fix the obvious problem first (it may well work with the chipped teeth if the slop is resolved) and potentially save a heap of dollars....get jiggy with things in the winter mate....you got the rest of the summer to ride and make maintenance plans :-)
Old Jun 29, 2012 | 04:56 PM
Dyna7's Avatar
Dyna7
Spanners i live in hawaii...its summer all year round haha
this weekend im going to just check and make sure ive got spark and check the bushing and i will keep yall updated
Old Jun 30, 2012 | 10:10 PM
Dyna7's Avatar
Dyna7
ok so i counted the starter gear teeth and its 102 and the pinion is 10, the stock is 66 and 9, why the change is what i want to knwo
Old Jun 30, 2012 | 11:01 PM
Spanners39's Avatar
Spanners39
To lower the gear ratio in order to make it easier for the starter to turn the motor.....like its in 1st gear rather than 2nd would be the best way to look at it.
