Starter gears grinding?
Old Jun 30, 2012 | 11:04 PM
Dyna7's Avatar
Dyna7
well i cant find any place that sells the 102/10 setup, any ideas?
Old Jun 30, 2012 | 11:09 PM
RidemyEVO's Avatar
RidemyEVO
I'm thinking the bushing spanners is refering to that you may be missing is the pc circled in red.
Old Jun 30, 2012 | 11:21 PM
RidemyEVO's Avatar
RidemyEVO
After closer look at your video I think its actually the bushing for the inner primary for the jackshaft that your missing which is making it flex.
Old Jul 1, 2012 | 01:44 AM
Dyna7's Avatar
Dyna7
nope that bushing is there, but as stated earlier i think the setup is off of a different year (late 90's ran the 102/10 setup) because the bushing is way to loose
Old Jul 1, 2012 | 07:31 AM
1997bagger's Avatar
1997bagger
Your starter clutch has let go, if the noise was coming from the ring/pinion area, you would have teeth missing. Been thru the broken teeth, failed starter clutch's and kick backs, horrible noise. Installed a AllsBalls starter, big cables, new battery that held up but eventually lowered the compression when having some head work done so you are on the right track by checking the starter.
Also note that the outer primary bushing holds that pinion against the ring gear so it is going to jump in the video when the primary is removed
Old Jul 1, 2012 | 11:20 AM
RidemyEVO's Avatar
RidemyEVO
My buddy has an s&s evo high compression motor in his 87 fxr and he had problem with it turning over but not grinding and he went to high output starter and although I could be wrong but I beleive he still has the staock 9 tooth jackshaft.
Old Jul 1, 2012 | 06:34 PM
Dyna7's Avatar
Dyna7
well i am about to pull the whole primary setup out to replace the jackshaft coupling to see if the other fits better than this one, and if it does, i will just replace the starter gear ( and some seals that where already leaking )
Old Jul 1, 2012 | 06:56 PM
RidemyEVO's Avatar
RidemyEVO
I always find half the battle is having the proper parts on hand.
jurgie
Engine Mechanical Topics
Apr 17, 2017 07:24 PM
jtyson
Shovelhead
Jul 21, 2015 03:40 AM
wedgehead
EVO
Oct 7, 2012 08:19 AM
95 Ultra
EVO
Mar 31, 2012 06:12 PM
Malibyte
Feb 26, 2012 05:58 PM
