Starter trouble
Old Mar 31, 2012 | 02:35 PM
95 Ultra's Avatar
95 Ultra
Default Starter trouble
The wife's bike-1989 Custom Softail-FXSTC. In the last few days the starter has started making a screeching sound when you press the starter button. When it does this, it doesn't feel like the engine is turning over. If I let off the button for a second and press it again, it usually engages and starts right up. It doesn't sound like the dreaded click, this is different. It seems to be getting plenty of juice, just not turning the motor over, like it's not completely engaging. I'm wondering if something inside the primary where it engages has worn out or is slipping. It's a pretty loud screeching sound. I've checked and cleaned the connections. I took the solenoid apart and cleaned inside it with emory paper. Any suggestions from you guys what to look for before I start replacing parts??? Thanks.
Old Mar 31, 2012 | 03:07 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I'd open the primary and look at the starter gear and the ring gear.
Old Mar 31, 2012 | 03:34 PM
Bama91's Avatar
Bama91
Agree with above. Sounds like the starter clutch or component in the inner primary isn't meshing with the ring gear properly. I would bet on the starter clutch though.
Old Mar 31, 2012 | 05:37 PM
SportsterBob's Avatar
SportsterBob
Check the starter gear bushing in the primary cover. If that bushings wears it will cause the starter gear to slip while engaging the ring gear. Had that problem 4-years ago.
Old Mar 31, 2012 | 06:10 PM
RidemyEVO's Avatar
RidemyEVO
As is already stated, open her up.
Old Mar 31, 2012 | 06:12 PM
Stiggy's Avatar
Stiggy
It's the starter clutch...about $50 for the part.
jurgie
Engine Mechanical Topics
Apr 17, 2017 07:24 PM
arod6
May 13, 2016 07:46 AM
Dyna7
EVO
27
Jul 1, 2012 06:56 PM
ConRic72
May 15, 2010 09:18 AM
Tuggin
EVO
May 20, 2008 11:18 AM
