Starter
Old May 18, 2008 | 07:39 AM
Tuggin's Avatar
Tuggin
Default Starter
Not sure whats up with my starter, though I have an idea. I did a search looking for my symptoms but came up with nothing. Most of the time when I start the engine cold the starter engages OK then after just acouple of seconds it sounds like a grinding noise thencontinuesOK until the engine starts. I don't notice it much when the bike is warm, could it be mystarter drive? My 98 SG only has 10 thousand miles on it. Are they hard to replace?
Tom
Old May 18, 2008 | 09:06 AM
sqdealgeorge's Avatar
sqdealgeorge
Default RE: Starter
Pull off the outer primary cover and examine the starter ring gear ( the gear that is attached to the clutch housing ) for broken teeth or chipped teeth If this is the case replace the ring gear
Old May 18, 2008 | 07:05 PM
dog155's Avatar
dog155
Default RE: Starter
Sounds like the starter drive,and it is a pain to replace.You have to pull the outer primary before you can pull the starter.Get a manual or borrow one.Good Luck
Old May 18, 2008 | 07:25 PM
Franko92's Avatar
Franko92
Default RE: Starter
Sounds just like the problem Im having with mine, I have a manual, but Im not looking forward to the work.
Old May 19, 2008 | 10:48 AM
Tuggin's Avatar
Tuggin
Default RE: Starter
dog155
When you say starter drive are you referring to the pinion drive gearthat engages the flywheel? My manual shows an overunning clutch inside the starter. Thanks for your input!
Tom
Old May 19, 2008 | 11:34 AM
dog155's Avatar
dog155
Default RE: Starter
Yes,the starter drive/overrun clutch, same thing.
Old May 19, 2008 | 09:18 PM
Tuggin's Avatar
Tuggin
Default RE: Starter
Thanks dog155. I am probably going to get into this job after the holiday, hopefully I will have some decent weather to ride in, it's been cold and wet here in the Northeast.[&:]
Tom
Old May 20, 2008 | 07:24 AM
dog155's Avatar
dog155
Default RE: Starter
What part of the NorthEast you from? We are west of Portland,Me.Windham.
Old May 20, 2008 | 11:18 AM
Tuggin's Avatar
Tuggin
Default RE: Starter
Mid Atlantic region actually, Meadville, Pa. (about 40 miles south of Erie)
arod6
May 13, 2016 07:46 AM
Pumba11
Aug 5, 2013 08:33 AM
Dyna7
EVO
27
Jul 1, 2012 06:56 PM
95 Ultra
EVO
Mar 31, 2012 06:12 PM
3boogitys
Feb 13, 2006 08:36 PM
