Can anyone walk me thru replacing the choke cable on a 97 FXDL? At first glance it looks like I might have to remove the tank to get to it. I'm hoping not.
Just undo the 11/16 nut at the back of the bracket that holds the choke ****, then remove the carby (don't forget to turn the gas off) unhook the VOES vacuum pipe and also, on reassembly, fit a new carb to manifold rubber.
The choke cable just unscrews from the carby body. Always a good idea to tie a string to the choke **** as you remove the carby and transfer that string to the new choke **** to make it easier to refit.
DO NOT OVERTIGHTEN THE 11/16 NUT WHERE IT MOUNTS ON THE BRACKET!!!! Its on a plastic thread and is real easy to break.
Thats the whole issue the plastic body on the the tennsioner broke. Is that actually a separate piece that can be replaced on it's own? I just assumed it was an assembly.
You have to remove the carby to get the cable out of the carby body, No need to remove the tank, that's just a pain in the butt doing that.
BTW....I have been waiting for someone to chime in with "Its not a choke it's an enrichener" but alas, I have been let down once more by the interwebs :-) :-) :-)
Okay gat as far as the air cleaner and the three screws for the back plate. I'm gonna have to gat a little more forcefull with the head breather bolts. When I put it back together am I going to need to get a torgue wrench for it or is as snug as I can get it acceptable. What are the chances of me snapping something by going too tight?
