evo tranny
Old Jul 23, 2012 | 11:14 AM
kgjl's Avatar
kgjl
Default evo tranny
Approximately how many hours of labor should be charged to go into the tranny?
Old Jul 23, 2012 | 11:31 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Are you taking about taking the tranny out of the frame or rebuilding the tranny itself?
Or both?
Old Jul 23, 2012 | 12:26 PM
kgjl's Avatar
kgjl
both.
Old Jul 23, 2012 | 01:14 PM
texashillcountry
Dirt don't hurt
Not sure about the hours but I was quoted $600 to R/R the tranny and it cost me about $300 to have them rebuild it.
Their shop rate is $85 an hour.
Hope this helps.
Old Jul 23, 2012 | 01:22 PM
RidemyEVO's Avatar
RidemyEVO
Most tranny work can be done in the frame, in fact I can't think of any reason for having to pull the tranny. I've always done my own work so I can't give a guestamit on shop cost but I do know I can be as far as getting to the big main seal in about 40 minutes and that includes loosening off starter bolts and
Removing left floor board. If I were to pull the gearset I would need to remove right side exhaust and floor board , right saddle bag and right tranny cover and then loosen off trap door and that would be about another 40 minutes or less, after that it's just a matter of pulling the
Tranny top cover , selector drum and forks and
Tap out the gear set, 20 minutes. After that it's what ever they do with what is needed.
So saying all that, why do you need tranny work?
Old Jul 23, 2012 | 04:31 PM
Spanners39's Avatar
Spanners39
6-8 hours is about right for a full rebuild on most Evo/TC 5 speed trannys....more or less depending on what is actually being done....remember that is "shop time" so includes test riding it afterwards and cleaning the grubby fingerprints off.
Old Jul 23, 2012 | 06:27 PM
kgjl's Avatar
kgjl
It won't shift. All I have left is 1st and neutral.
Thanks for all the replies.
Old Jul 23, 2012 | 06:42 PM
RidemyEVO's Avatar
RidemyEVO
Is the shifter arm off the tranny stiff with spring back tension going
Forward and to the rear? Could be number of small issues.
Pull the top tranny cover off and take a look, it may be as simple as a bent shift fork.
What yr and model?
Old Jul 23, 2012 | 06:44 PM
miacycles's Avatar
miacycles
Obviously it would depend on how far the tech needs to go to find the problem and how competent he is. Mechanics can charge "book time" or "time and materials". Usually they charge which ever is the longest as most are in business to make money. If it's the shifter pawl spring (which would be my first guess), then the tranny needs to have the gearset completly pulled. If the shifter pawl is just out of adjustment then the whole deal of diagnosing and adjustment should be under two hours max, plus a gasket.
John
Old Jul 23, 2012 | 10:08 PM
Spanners39's Avatar
Spanners39
You can get the shifter arm assy out without removing the gear set or opening the primary, I have done it a couple of times....you won't find it in the manual but its easy enough to do.
