Flushing the engine out
Old Jul 28, 2012 | 03:30 PM
grbrown's Avatar
grbrown
Talking
We have access to a great deal of things these days that wasn't available when I started riding over 40 years ago. Multi-grade oils is one of them, cartridge oil filters is another. Our Harleys are designed to superior levels of quality, made of finer grade materials, machined to much closer degrees of accuracy since those two were introduced. We are spoiling them rotten just putting in modern oils! Let's not go over board.
Old Jul 28, 2012 | 04:25 PM
Spanners39's Avatar
Spanners39
There are many reasons not to flush a 50 K motor that has never been flushed before....it can dislodge gunk that can block oil lines and oil ways......seen it happen a few times.
Old Jul 29, 2012 | 01:03 AM
Schex's Avatar
Schex
My oil is so clean after a oil change, for the first 300 miles or so I have to lay the stick on a paper towel to see where the level is.
It's still pretty clean when I change it at 3500-4000 miles.
I get a additional pint or more of old oil out after I fill my tank with new oil, and not with that scavenger thingy.
Very Simple, the filter on a Evo is on the return to the tank.
Cut the very bottom off a used filter, screw it on,
hold a funnel or plastic soda bottle with the bottom cut out, up to the cut off end of the filter to catch oil(horizontal filter on my '97 softail),
on my '90 ultra the filter is under the bike, just place a pan under the filter.
the cut filter is just to not make a mess, even though the return oil is under very little pressure because there's no restriction in the line.
After filling oil tank, start the engine and watch the oil coming out, when it gets clean, stop engine, put your new filter on, top off oil tank, run engine till warm, check oil level, done.
No damage to bearings or lifters as there is normal oil pressure(I used to watch the gauge just to make sure), as the filter is on the return to the tank.
Just don't run too much oil out the tank, usually clears after a little more than a pint.
The oil in the softail I bought a few weeks ago was very black, I cycled an extra quart through it to clean it up, it's much better now and still clear after a couple hundred miles.
Old Jul 29, 2012 | 05:39 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Schex3x what is the difference between your method and simply taking off the return line from the oil tank and running it to a drip pan?
Old Jul 29, 2012 | 08:01 AM
HGM's Avatar
HGM
I completely understnad the opinion that it is not necessary. However, I fail to see why so many are SO adamantly against it.. It is NOT a flush! It is simply a complete oil change.. It wont losen up anything that the regular oil change doesnt, it simply removes all of the old oil... I have yet to do it, but how can it possibly be a bad thing?? Anytime you can get ALL the **** out of your engine, its a good thing.. Todays oil is far better than in the past and change intervals are not so much for oil breakdown, its more about getting the suspended trash out of it, stuff the filter cannot remove, the BLACK stuff. This is the primary reason I do not belive in synthetic's in general..
Old Jul 29, 2012 | 08:19 AM
TORQUEY's Avatar
TORQUEY
I use the Scavenger also. Its merits are quite apparent. Is it necessary? Of course not. However, I'd like to have someone explain how having absolutely immaculate oil can harm anything, especially for the HUGE financial outlay of $60.
So far, this enormous expense has cost me about $15 more an oil change, or just a tad more than ONE QUART of synthetic oil. In 4 more oil changes, that becomes $7.50 per oil change and so on. Very soon, it will be adding the cost of a small coffee to the oil change. Wow, do we love to throw our money away or what?
Old Jul 29, 2012 | 09:17 AM
texashillcountry
Dirt don't hurt
Since you will be adding more oil than you normally would every oil change I don't see how the cost of an oil change will be going down.
Old Jul 29, 2012 | 10:35 AM
Schex's Avatar
Schex
It takes me less than a minute to get all the left behind old oil out.
I rather not fight oil lines in tight spots, make oily mess, and possibly damage the oil line.
Old Jul 29, 2012 | 03:29 PM
D1gger's Avatar
D1gger
+1 The return to the oil tank is kind of difficult to reach, at least on my bike, and the easiest way to reach it is to remove the tank mounting bolts and pull the tank away from the frame a little. Of course that requires pulling the battery, the upper trim and moving a wire harness. Schex3x's method sounds very quick and easy. When my next change comes up, I plan to implement his method.
Old Jul 29, 2012 | 03:44 PM
Doug S's Avatar
Doug S
For me, there is a big difference between flushing a motor and scavenging the oil from one. A motor gets flushed when one adds some kerosene or a store-bought flush and runs it to get the sludge loose. What has been described here is scavenging and I can't see it doing any harm if done properly. I would not mess with the oil lines because that is a good way to induce a leak, the puck or cut off oil filter are ok.
Personally, I change it every 3K and try to stay away from the stator plug-(wiggle it around enough and you will have a leak)- when removing the filter so I don't bother trying to catch the oil from the old filter or scavenge the engine. Been working like this for years..
Ds
