FXR Fork Q
Old Jul 31, 2012 | 01:02 AM
KevH's Avatar
KevH
Default FXR Fork Q
What legnth forks did the 1992 FXR Super Glide Standard have? Were they they tall ones like the FXRT or were they the shorter ones like the Low Rider?
Old Jul 31, 2012 | 03:34 AM
grbrown's Avatar
grbrown
Interesting question. I suspect they were the short ones. The FXRS and FXRT, also the Police version all had twin discs and tall suspension as best I recall.
Old Jul 31, 2012 | 05:17 AM
Redhill Phil's Avatar
Redhill Phil
The FXRS-SP had the longer ones as well
Old Aug 1, 2012 | 12:46 AM
Then Came Bronson's Avatar
Then Came Bronson
A standard FXR did not have the two inch over forks and dual discs that were standard on the FXRS-SP, the FXRS-Convertible, the FXRT, and the police models.
Old Aug 1, 2012 | 11:13 AM
Lakerat's Avatar
Lakerat
So, is it accurate to say that all single disc Fxr's have short tubes and all dual disc FXR's are 2" longer?
Old Aug 2, 2012 | 01:40 AM
Then Came Bronson
Not completely true. There were so many variants of the FXR over the years, that it's hard to keep track of them all. Also, calling them short tubes is not an accurate statement. I would call them standard length forks.
Harley started marketing the "sport package" around 1986 or '87. It was an option that could be had for a couple of hundred more bucks. The FXRS-SP was officially designated a "model" around 1988 or so. I think it was the first model marketed with the taller suspension (2" over front forks, longer rear shocks) and dual disc brakes up front. The FXRS-SP model is also verified by the two letters "EG" in the 5th and 6th position of the VIN.
Old Aug 2, 2012 | 12:56 PM
Lakerat's Avatar
Lakerat
So, what are some examples of FXR's with the short(standard) tubes with dual discs. Just trying to learn something here.
Old Aug 3, 2012 | 05:34 AM
Then Came Bronson
Well, the 1982 FXRS comes to mind…same with the '83. It came with 35mm forks in only one length, with dual disc brakes.
Old Aug 3, 2012 | 11:49 AM
Lakerat's Avatar
Lakerat
Thanks, any with 39mm tubes? The reason I'm asking is because some day I would like to change my FXLR over to duals if I find the right deal.
Old Aug 3, 2012 | 10:41 PM
Then Came Bronson
Check to see if your right slider has the mount for brake caliper. If not, can't you just buy a right slider off of a bike that had duals? Also, not sure if your wheel's hub is set up for another disc…I don't think it is.
I just noticed you sig pic. Your FXLR looks lowered…is it? The front forks look shorter than normal, and so do the rear shocks. Just curious.
Kayakeur
EVO
Nov 21, 2017 09:12 PM
agueybana
Mar 21, 2014 05:26 PM
DBLJ
EVO
28
Jun 1, 2011 04:16 PM
7373pisces
May 24, 2009 12:27 PM
markII
EVO
27
Jun 13, 2007 04:11 PM
