back fires thru carb
Old Sep 3, 2012 | 09:20 PM
langwilliams's Avatar
langwilliams
Default back fires thru carb
I got my 93 softail runnin good but when you park it sometimes it backfires through the carb. I replaced the slide an diaphram an accellerator diaphram, cleaned all the jets an passages an float needle tip. starts an runs well, idles well, just gets a backfire when I shut it down.
Old Sep 3, 2012 | 10:20 PM
Spanners39's Avatar
Spanners39
Sounds like its running a bit advanced on the ignition timing to me.....
Old Sep 4, 2012 | 02:55 AM
jjames's Avatar
jjames
What octane gas are you running thru? Dealership put 87 in when I picked it up after buying and it did that when I shut it down almost every time that first tank. Now with 92 it hasn't happened. My old corvette will do it too if it doesn't get high test when on road trip and po dunk stations only have 87.
Old Sep 4, 2012 | 08:18 PM
langwilliams
I run 89, may try 91, timing hasn't been touched.
Old Sep 4, 2012 | 09:18 PM
langwilliams
"Sounds like its running a bit advanced on the ignition timing to me"
Hummm....the dude that checked my carb dialed the idle up, wondering if it's enough to kick in the advance. I backed it down, hope that helps.
Old Sep 5, 2012 | 07:12 AM
GraemeR's Avatar
GraemeR
Doe sit do the problem on decelleration? if so then what size Pilot Jet are you running. I ran one that was too lean .45 and the backfireing blew up the slider completley! Fitted a .48 and all is well now.
Old Sep 6, 2012 | 03:17 PM
IronWright's Avatar
IronWright
spanners sounds right....also..how many shots u give her before startin???
Old Sep 6, 2012 | 07:39 PM
badcooky's Avatar
badcooky
Go spanners.
Old Sep 6, 2012 | 08:30 PM
mostSilly's Avatar
mostSilly
possible intake leak at one of the heads?
Old Sep 6, 2012 | 08:48 PM
Jethro's Avatar
Jethro
Give us some more info... Carb type, (assuming stock cv) and you main and slow speed jets. Do you have any mods? Do you have any backfiring or "popping"on decel? What do the plus look like?
