Cam install issue
Old Oct 14, 2012 | 03:54 PM
HDFatboy98's Avatar
HDFatboy98
Fml the mech didn't adjust them. I took the pushrods back and they simply just weren't ran up. Couple of hours later everything seems to be ok
HDFatboy98's Avatar
HDFatboy98
+1 should have done more research and done it myself I think
Old Oct 14, 2012 | 04:23 PM
JohnnyC's Avatar
JohnnyC
Your learning. Sometimes there's an easy way to learn and sometimes we learn the hard way. Just glad it wasn't a costly mistake!
After the last misadventure I had with a "Harley Independent Mechanic" leaving me with more major issues by overlooking some very basics I swear I will be the only wrench working on it as long as I can.
Best wishes and Ride On!
Old Oct 14, 2012 | 07:29 PM
Spanners39's Avatar
Spanners39
That wrench needs a good hard slap!!!!
Old Oct 16, 2012 | 03:47 PM
HDFatboy98's Avatar
HDFatboy98
Are adjustable Pushrods a little more noisy than stock ones?
Old Oct 16, 2012 | 07:18 PM
Spanners39's Avatar
Spanners39
Nope....
Old Oct 16, 2012 | 09:19 PM
HDFatboy98's Avatar
HDFatboy98
Well I have some adjustments I'm going to make this weekend. Thanks everyone
Old Oct 16, 2012 | 09:29 PM
shovelhead FXEF's Avatar
shovelhead FXEF
Make sure it isn't the cam and pinion gear slab your hearing. Loose clearence although noisy is better than to tight. Double check the gear clearence.
Old Oct 16, 2012 | 10:19 PM
Spanners39's Avatar
Spanners39
Hot cams are noisier by nature so just make sure the lash in the gears is OK, pushrods adjusted right and then ignore the noise that remains...
Biker Boy 53
Aug 27, 2015 08:48 PM
Pinetop
EVO
33
Sep 24, 2014 10:05 PM
omgtkk
EVO
Feb 13, 2011 04:36 PM
HutchNJ
EVO
15
Feb 9, 2008 11:21 AM
GEARMASHER
Exhaust System Topics
Apr 21, 2007 04:02 AM
