Cam install issue
Old Oct 13, 2012 | 08:37 PM
HDFatboy98's Avatar
HDFatboy98
Default Cam install issue
Okay guys I gotta problem and I need some wisdom. I was in the process of doing the do. Removed old cam, inner bearing, etc. Well doing the install new Torrington bearing installed, new cam, new adj pushrods(Andrews chromoly), rolled the engine over wasn't bound up, and reinstalled everything.
Moment of truth came and then... Nothing. Sounded like it wasn't turning over. Went back through and the pushrods weren't right (exhaust rods are longer than intake). Reinstalled them and checked again, then nothing. Same sound like the motor wouldn't turn over. Any help is appreciated.
Old Oct 13, 2012 | 08:49 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Did you plug the ignition pick up back into the ignition module?
Old Oct 13, 2012 | 08:52 PM
HDFatboy98's Avatar
HDFatboy98
it wont turn over, but i was just looking at the nightrider site and I think I know exactly is wrong I didn't align the timing on the gears up right. I messed up. Well, I'll be pulling it all back apart in the morning, but atleast Im feeling sure about what the problem is thank you
Old Oct 14, 2012 | 06:13 AM
1997bagger's Avatar
1997bagger
You have to had a valve on top of the piston locking it up, lets hope no damage was done, you will know shortly
Old Oct 14, 2012 | 06:34 AM
HDFatboy98's Avatar
HDFatboy98
I'm hoping too, but when we pulled the pushrods out they were not bent. I hope no internal damage was done either I start thinking dollar signs, plus I have 2 other projects running.
Old Oct 14, 2012 | 10:30 AM
HDFatboy98's Avatar
HDFatboy98
Update. Picked it up from mech this morning and everything was good for about 10 miles then I started getting what sounded like chatter from the pushrods and then the bike lost power and cut off. I'm waiting on a tow right now. Any ideas what the problem could be? I'm thinking check the pushrods when I get towed home.
Old Oct 14, 2012 | 11:18 AM
texashillcountry
Dirt don't hurt
If you have adjustable push rods it sounds like the mechanic didn't tighten up the lock nuts on the push rods and they came out of adjustment.
Old Oct 14, 2012 | 11:23 AM
HDFatboy98's Avatar
HDFatboy98
The Andrews pushrods I bought didn't have a jamnut/locknut I'm going to pull it apart when I get home and I'll report what I find thanks for the reply Tex
Old Oct 14, 2012 | 11:37 AM
miacycles's Avatar
miacycles
I have never seen adjustable pushrods without locknuts!!
John
Old Oct 14, 2012 | 11:51 AM
texashillcountry
Dirt don't hurt
Then you got a defective set.
You have to have lock nuts to keep them in adjustment.
