TPS calibration is vital on setting up a PowerCommander also, does the S&S have a function to calibrate TPS by a idle to 100% throttle roll?
Some good monitoring numbers shown that can help with diagnsotics and tuning on that screen
The TPS itself can only be adjusted manually for it's initial voltage setting. The next voltage setting involves the hot idle screw...the cold idle setting can be ignored completely until all other parameters are finalized. Yeah, that TPS setting is very sensitive to adjustments...just tightening the sensor screws down can change the value.
