95 FLSTC Won't start
Old Nov 17, 2012 | 06:05 PM
Cap'n Parrothead's Avatar
Cap'n Parrothead
6th Gear
Default 95 FLSTC Won't start
I just got 95 FLSTC from a deceased relative. I had a 92 FLSTF for several years but it always ran like a top. Never had much work to do on the old one. But this 95 has been sitting for a few months. So far I have replaced the Plugs, Plug Wires, Battery, checked the fuel, oil, and can see fuel going into Carb. She still won't start. Any ideas or helpful info would be greatly appreciated. Thanks!
Old Nov 17, 2012 | 06:34 PM
Spanners39's Avatar
Spanners39
Always check to see if it has a spark first, then check that fuel is reaching the spark and then check that its the right amount of fuel and the spark is happening at the right time.
A quick squirt of ether down the carby will tell you a lot, the bike will either fire or it won't.....if it doesn't fire on ether then it has no spark but actually looking at the plugs with them sitting on the cylinder will be the best test.
Do some checks and get back to us...we are here to help....and jeer and laugh if you screw up ;-)
Old Nov 18, 2012 | 06:13 AM
grbrown's Avatar
grbrown
The more you tell us the more we can help. I take it the starter turns the engine over fine?! To light the fire you need fuel and electrics. If the bike has been standing unused and bearing in mind it is many years old, there may be any number of silly things that need attention, like poor earth/ground connections, dirty contacts. Check and clean wiring from the battery through the ignition system. I would also drain the gas from the tank and carb, clean and refill with fresh. Give the old lady every chance to fire up and run!
Old Nov 18, 2012 | 09:38 AM
Cap'n Parrothead
6th Gear
Yes the starter seems fine. She will try and try but just not go... I will try the suggestions and re-post with any progress. Also, will keep you up to date with any blunders or screw ups, the jeers and laughter will help ease the frustration. Thanks again!!
Bigfatty
Aug 5, 2021 10:39 PM
AFORAL
Nov 19, 2018 09:25 PM
npsocal
Carburetor Related
Aug 11, 2015 05:26 PM
Celticknott
May 18, 2011 09:56 PM
shagga
Mar 27, 2007 08:03 PM
