Dyna Drive Belt Replacement - Tutorial Anyone?
Old Dec 3, 2012 | 04:35 AM
unnnivers's Avatar
unnnivers
Originally Posted by Spanners39
Many people get the jackahsft assy ***-backwards so you might wanna check its not that before going into the electrics.....did you reconnect the earth strap?
Jackshaft assembly is completed correctly. I can turn it and feel the rotation of starter motor shaft. Ground cable's (earth strap) clamp is connected at the same place - on the starter mount bolt. Turning an ignition switch lights come on, but pushing start switch - only click of relay - no noticeable reaction into starter body - absolutely quiet. The strangest thing that surprised me -I did nothing more than only mechanical work - didn't touch any electrics excepting ground cable.
Old Dec 3, 2012 | 06:17 AM
Kabear's Avatar
Kabear
Here is a ridiculous suggestion that sometimes works, it happened to me.
When re-assembling the primary you may have engaged the starter gear in the clutch gear. If that happened, the starter doesn't get the "start-up" power to turn the engine over.
Engage the transmission and push the bike forward a little just enough to bump the starter gear out of engagement.
Might help, worth a try and easiest thing to try.
Old Dec 3, 2012 | 06:22 AM
Scudda's Avatar
Scudda
Would love to see it!. That way I have something to reference when I need to do it to my 95 FXDL
Old Dec 3, 2012 | 06:29 AM
unnnivers's Avatar
unnnivers
Thanks for help Kabear, but it isn't it, the primary cover is opened still, and I saw - positions you described are o.k.
Old Dec 3, 2012 | 01:48 PM
Spanners39's Avatar
Spanners39
So you can see the starter jackshaft and it doesn't turn when you press the switch?
Are you sure its the relay clicking and not the contact breaker? Your starter connections might be grounding on the frame.....
Old Dec 3, 2012 | 07:39 PM
u wish u could ride's Avatar
u wish u could ride
in on this ...
Old Dec 3, 2012 | 10:16 PM
Kabear's Avatar
Kabear
That is your problem, the outer bearing for the jack shaft is in the primary cover. so the shaft is at an unusual angle and cannot turn, it is locked up.
Place the primary cover back on and try again, I bet it works then.
Unless of course you mean open, as in derby cover. But I don't think you could see the starter shaft through the derby cover.
Old Dec 4, 2012 | 01:36 PM
Spanners39's Avatar
Spanners39
Starter should work with the primary off, I always test them before replacing the outer primary as the apprentice has been known to get them in back to front (as have I) and its a PITA to pull the primary just to correct that.
Old Dec 4, 2012 | 03:40 PM
IronWright's Avatar
IronWright
Old Dec 4, 2012 | 04:14 PM
Spanners39's Avatar
Spanners39
I will save them upside down so you can see them and also find some way of dealing with the fact that our Harleys are left hand drive.
