Electrics? Maybe more...
Old Dec 9, 2012 | 05:12 PM
miacycles's Avatar
miacycles
Start wit he battery connections at both ends of the cables, make sure they are tight and clean. Then check the main circuit breaker (a volt ohm meter is the best way, but a test light can be used) for power going in and out. Then just keep moving along the power stream until you find the culprit. Pay attention to the ignition (key) switch and the stop/run switch. Although with the lights out it is probably one of the others mentioned. Hope this helps.
John
Old Dec 9, 2012 | 07:21 PM
Dr.Hess's Avatar
Dr.Hess
No power anywhere is easy to trace down. Start at the battery and go forward from there. Check your ground too. It goes: Battery to starter solenoid to main breaker. I bet your problem is in there or the battery ground wire.
As for the hard starting, are you using the enricher? Is the enricher lever actually attached to the enricher plunger thingie on the carb? It is not hard to put the backing plate on and not have that lever attached to the plunger properly. Don't ask me how I know that.
Old Dec 9, 2012 | 07:46 PM
Harleycruiser's Avatar
Harleycruiser
Does it crank, does it crank slow just not start?
Old Dec 9, 2012 | 07:55 PM
RidemyEVO's Avatar
RidemyEVO
If you want a quick check after checking battery to solanoid bypass circuit breaker just to see if you got full circuit, if it cranks you found culprit and if it acts the same reconnect circuit breaker and continue tracing.
By the way circuit breakers are cheap and do get tired.
Huggerbugger
May 27, 2016 02:54 PM
n.texan
Ironhead
74
Apr 25, 2012 06:19 AM
BearFace
Aug 20, 2011 12:50 PM
TurboExempt
Aug 6, 2008 07:53 PM
panicSG
Classic
11
Apr 21, 2008 02:07 AM
